Generator Light
Old Sep 6, 2014 | 03:22 PM
jamhh's Avatar
jamhh
Generator Light
Today my truck acted odd. Its been parked for a couple weeks. Started right up like normal, however the generator light laminated. The more RPM, the brighter the light. Then it corrected it self. But when I parked the truck and turned off the key, both generator light and oil light stayed laminated. It wasn't until I disconnected the battery that they went out. After reconnecting the battery, the generator light did the same. I'm thinking regulator???? Suggestions
Old Sep 6, 2014 | 04:06 PM
Tedster9's Avatar
Tedster9
Stuck cutout points? Sometimes there will be nice big dents in the regulator cover on originals. Banging on it was the field expedient way to clear.
Old Sep 6, 2014 | 04:13 PM
jamhh's Avatar
jamhh
There are 3 sets of points "A" "F" and "B" as there are marked. Nothing appears to be stuck
Old Sep 6, 2014 | 04:32 PM
Tedster9's Avatar
Tedster9
Guess I'm a little unclear on your post - OFF - you mean OFF, same as in "no key installed"? Both OIL and GEN lights should illuminate in RUN, when first starting, to show bulbs are OK. The OIL light illuminating (in the OFF position) has me a little puzzled, though. That wouldn't have anything to do with the regulator, iirc.
"After reconnecting the battery, the generator light did the same. I'm thinking regulator??"
You mean to say the GEN light comes back on? (But not the OIL light) It could indicate stuck cutout relay. Be sure the cutout points don't close until 1000 or 1200 RPM, something like that.
Old Sep 6, 2014 | 04:43 PM
spurredon's Avatar
spurredon
With you mentioning the oil lite as well, it makes me wonder about the key switch.
Old Sep 6, 2014 | 04:46 PM
jamhh's Avatar
jamhh
Yes the light stayed on after engine off and key out of ignition
Old Sep 6, 2014 | 04:52 PM
Tedster9's Avatar
Tedster9
Hm. So the switch is failed, in the RUN position, something like that, maybe dirt/corrosion?
Had to replace the 64's, can't recall why exactly. I would try a big ole slug of contact cleaner directed to the innards, and work the switch itself back and forth a few times. WD40 or lighter fluid, in a pinch would do, might be a workaround while new switch is on order or maybe this will solve the problem.
spurredon's Avatar
spurredon
Sounds like you have switch troubles to work on first. Maybe just working it back and forth will free it up since it has been sitting but I would be looking around for another.
Old Sep 6, 2014 | 05:02 PM
spurredon's Avatar
spurredon
Here's one :Ignition Switch Housing Assembly | Dennis Carpenter Ford Restoration Parts
Old Sep 18, 2014 | 10:17 AM
jamhh's Avatar
jamhh
just to clear things up. As my description was vague. I since got the oil light issue solved. Now the generator light. When the truck is at idol rpm the light has a very low glow, which I believe is normal, but as I increase rpm the light gets brighter to full lumination at high rev's
Old Sep 18, 2014 | 11:49 AM
Tedster9's Avatar
Tedster9
Either regulator isn't regulating or generator isn't generating. Sounds like the latter. Measure battery voltage at 1500-2000 RPM and see what we have.
Old Sep 19, 2014 | 08:19 AM
Lahti35's Avatar
Lahti35
I've got this exact same issue in my '60 F250. I replaced the regulator, no change. I rebuilt the generator, no change. I cleaned all the wire connections for the regulator and generator, no change.... I take that back there was a change, the light just got brighter after the cleaning!
I'm onto rigging up a short stretch of new wire hooked to a generator bulb to see if it still does it. Maybe a wire is corroded somewhere and causing some resistance which would make the bulb glow since all it does is see a difference in voltage to light up.
In the mean time if you find a solution let me know, lol!
Old Sep 19, 2014 | 10:15 AM
Tedster9's Avatar
Tedster9
"It's been parked for a couple weeks"
Wonder if it could be our old friend, corrosion? Rust never sleeps. One thing that helps is make sure the generator mounting brackets and block surfaces are clean since the return path current flows through there. I had a tough time getting voltage adjustments dialed in until everything was cleaned up.
It "shouldn't" be necessary, but also try polarizing the generator by disconnecting the field and batt wires at the regulator and touching them together momentarily.
Jonesy0027
Jan 7, 2024 11:29 AM
brc777
1997 - 2003 F150
26
Jan 16, 2019 10:25 AM
Rusty_S
Aug 26, 2015 08:51 PM
Coalroller
Feb 7, 2012 11:26 PM
Kevin Lee Allen
1983 - 2012 Ranger & B-Series
Oct 15, 2005 12:29 AM
