4.6L engine and trans mount location?
Old Sep 27, 2006 | 07:43 PM
54fever's Avatar
54fever
Hey guys,
I need help! i plan on installing a 4.6L cobra engine in my 54 and would like to weld my engine and trans mounts in before i get the motor(which will be along time from now!). My need to knows are, what frame mounts to use on my tci cross member and the center to center distance from the engine mounts to the trans mount holes. I will be running a auto trans with the 4.6L. The reason for all this premature need is because i want to weld everything in before i paint, any of this make sense?
Thanks fever
Old Sep 27, 2006 | 08:33 PM
Randy Jack's Avatar
Randy Jack
fever -
FWIW, I would NEVER weld in motor mounts before I have the engine in hand.
You are a braver man than I.
Old Sep 27, 2006 | 08:38 PM
4tl8ford's Avatar
4tl8ford
You put the mounts on the engine and transmission, place it, move it, adjust it some more, tac them in. then decide where you really need them.
Old Sep 27, 2006 | 11:13 PM
54fever's Avatar
54fever
Yeah! i know what you guys are saying and i agree, just trying to figure out what i can do other than buying a junkyard motor and trans for a mockup. So with that said i think i better just spend the money for the junkyard motor and trans (about 200. bucks is what the salvage guy quoted me) or wait until i get the set i want then grind off the paint weld the mounts in and touch up the paint.
Old Sep 28, 2006 | 09:48 AM
OldgreenF1's Avatar
OldgreenF1
Your doing the fuel injected thing right?
Fuel injected engines require a pressure return line, meaning you have to change your fuel tank also or atleast rig up something for the second line returning in to the tank for the over pressure or I could be totally wrong depending on how ford set up the new cobra engine. Theres more to it than just putting in the engine and computer on the new stuff.
Old Sep 28, 2006 | 05:07 PM
51dueller's Avatar
51dueller
Depends on the year, up to 1998 Ford used the return line system but 1999 and on used a return-less system. That system requires a different fuel pump.
Old Sep 29, 2006 | 01:17 AM
keith56_cruz_cab's Avatar
keith56_cruz_cab
fever- I put an 01 cobra with a tci ifs in mine had to make the mounts
so will you. Dont even think about makin it all pretty with paint and such
right now youve got a long way to go
54fever
Feb 10, 2007 08:29 PM
54fever
Jun 3, 2005 07:31 PM
54fever
Dec 13, 2004 03:38 PM
Yellardawg
1997 - 2003 F150
Mar 19, 2002 04:36 PM
