Cab to frame mount info needed
Hi guys,
Can some one give me the bolt hole center on the cab frame mounts, i had to cut that part out and replace it with new metal. I took measurements before i removed them but left the paper with the measurements in my pocket and..... well, they got washed along with my shirt . Also i will need to know the bolt hole size.
Thanks Ernie
Thanks Ernie
Ernie,
I have a lot of metal missing in both of the front lower corners of my 56 cab. After removing the "patch panels" the PO had applied with pop rivets, there wasn't much left of the cab near the front cab mounting holes.
The distance from the center of the hole in the left frame extension to the center of the slot in the right frame extension is exactly 55". The hole in the left frame extension and the slot in the right frame extension are where the cab front supports rest. The right side is slotted to allow for a little variation in the cab mount width from cab-to-cab. Remember, I have a 56 - not sure if the measurement is the same on your 54.
Erniebob
12-11-2010 06:06 PM
54fever
39
05-23-2005 10:06 AM
texas60guy
01-06-2004 10:41 PM
