Sometimes when I turn off my truck it knocks a little, and the shut off is delayed. It's a 78 F250 4 x 4 with the straight 6. Thinking it may be the timing.
Great thanks guys! I'll check it out in the morning. By the way it came with an extra hood. I used to do body work so I don't need it, just need a little help on the mechanical side.
It's not running to hot is it? That can cause it too. Actually, I usually richen the idle mixture a bit to keep the combustion chambers a little cooler.
But usually lowering the idle a little and maybe slowing the timing just a tad will fix it.
