Modular V10 (6.8l)
2003 v10 engine knock
Old Apr 26, 2011 | 09:16 PM
tgen17's Avatar
tgen17
I have an 03 f250 V10 that Ive had for about 4 months. recently developed a knock at about 2000 rpm and above. the weird thing is that is seems to be much worse when the car is in park. If you hold the rpm the knock will fade and sometimes stop alltogether. it will only knock when it is in drive above about 3k rpm. Also it doesnt seem to be consistatnt. sometimes it wont knock even if I floor it. It will also knock when it is cold and I first start it up but only for about a second.
Took it to my backyard mechanic and he determined that it was coming from the bottom end of the engine
truck has 107k and has never towed much. (I knew the former owner)
knock sounds like a woodpecker
Spun rod bearing???
help.
Old Apr 27, 2011 | 10:25 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
That sounds like the thrust washer. Time to check the crank end-play.
It COULD be bearings, but check the crank end-play which can be done without removing anything except maybe the fan belt.
Old Apr 27, 2011 | 06:49 PM
tgen17's Avatar
tgen17
thanks ill give it a try and report back
dussell
Sep 28, 2016 01:30 PM
Shuuz
Jul 24, 2016 12:04 PM
PEG
1997 - 2003 F150
Nov 18, 2015 12:55 PM
erwatt
Aug 24, 2015 11:32 PM
RedDevil460
53
Mar 29, 2014 08:16 PM
