Coolant Change
Old Sep 27, 2006 | 03:27 PM
makthenif's Avatar
makthenif
Coolant Change
What is the correct coolant for use in a 2000 F150 4.2? Also, does the plastic T unit from the Prestone Flush and Fill kit affect the coolant and thereby damage the cooling system? Thanks.
Old Sep 27, 2006 | 04:12 PM
BrianA's Avatar
BrianA
You can check the owners manual for specifics, but in general the standard for the 2000 F150 is a 50/50 mix:
50% regular glycol based antifreeze (like regular old Prestone) and 50% distilled water.
Not sure about the plastic T you asked about.
I doubt it would be a cause for concern as far as damaging the coolant. I do not know where the T fits into the system. Where does it go? Does it get left in the system after the flush?
FWIW, I'd be sure to use distilled water. The 4.2 has shown some propensity to build up crud in the radiator as the miles rack up. (upwards of 125,000 or so) I believe part of this might be galvanic corrosion and part may be due to not using distilled water.
So, regular flushes and refills with fresh coolant are likely a good idea.
Headviking
May 17, 2012 10:42 AM
amd_038
Aug 20, 2011 08:03 PM
don77
23
Jan 1, 2009 09:20 PM
mcallister
Mar 23, 2008 06:40 AM
JoeBob1901
1978 - 1996 Big Bronco
Oct 25, 2002 11:29 PM
