Abs Light
Old Sep 30, 2006 | 07:06 PM
wndrnet1017's Avatar
wndrnet1017
SHELL' BIG TRUCK ABS Light
We have had the rearend of the truck rebuilt, this summer in fact. Replaced bearings and ring and inspected everything else. I replaces the VSS this morning and that did the trick. ABS, overdirve and speedometer all work perfect. Thanks for pointing us in the right direction. BTW- the part was $22.90 at the dealer and took less than 15 minutes to replace.
Old Sep 30, 2006 | 08:34 PM
totin_tools's Avatar
totin_tools
I had the abs light go on but not the od light problem. My problem ended up being the front wheel bearing and hub.
Old Oct 3, 2006 | 08:18 AM
SHELL' BIG TRUCK's Avatar
SHELL' BIG TRUCK
Thumbs up Thanks
Just wanted to say Thanks for the info on the wheel speed sensor. Worked like a charm!
Old Oct 5, 2006 | 08:11 PM
FARM69's Avatar
FARM69
Hmm.. One of our farm trucks seems to have this same problem. The speedo doesn't work and the ABS light is always on. Its a 5-speed. I hope the rear end is not on its way out. How often do this sensors go out?
Old Oct 5, 2006 | 08:42 PM
Betthebux's Avatar
Betthebux
If both speedo and ABS are not working (and overdrive flashing on auto) I would suspect the VSS. If only one symptom then could be something else.
Old Oct 6, 2006 | 02:37 PM
John311t's Avatar
John311t
Well, if metal practicles get onto the sensor it will make the sensor not pick up the tone ring and it will give the same results. The sensors go bad more though than the rear end
truckdocter
May 22, 2011 05:02 PM
artguy
May 4, 2011 07:12 PM
gvsu141
1997 - 2003 F150
May 25, 2007 02:30 PM
seymor lost
Nov 23, 2004 05:28 PM
