i have a 2000 f250 superduty 4x4 i switch on and drive off when i reach around 30mph od light flashes i plug in computer with engine still running fault code p0500 is there but i have no problems with shifting or od speedometer and abs is working ok if i turn off engine and turn on again reconnect computer fault code is not there untill i drive off again,
anyone out there can help please
thanks
truckdocter
Your VSS is apparently intermittent. That sensor is on the top of your rear differential. Easy to replace. But could easily be a bad wire or connector too.
