stay running vs. shutting off and restarting
ive always heard that its cheaper to let a diesel run for a while longer, than it is to shut it off for a few minutes and restarting it. (ex. running in to the grocery store for a few minutes.) is there any truth behind this? im looking into possibly getting a diesel, and was surprised to hear that they are so fuel efficient.
It's not cheaper, it still uses fuel.
The problem with prolonged idling is a condition known as wet-stacking. This is un-burnt fuel that can coat valves and whatnot and cause problems down the road. I've let my truck idle every now and then, but not more than just a few minutes. Normally I just shut it off and run inside the store or whatever.
You do want to let a turbo diesel idle for a period of time after driving it for a while before shutting down. The reason is to let the turbo cool down so that after shutdown hot oil doesn't coke on the bearings. If you have a pyro, letting the temps settle to around 300 degrees or so is ideal for shutdown.
Also it aint 1980 anymore and since we drive computer controlled engines, wet stacking is not the problem it used to be in the early years. especially if you live in the southern climate. My 99.5 has over 220K on it and it idles for two to three hours a day( it is my mobile office ), and I have never had an issue.
this subject has been discussed before on this board and other boards, the consensus is if you want to be sure add an idle contoller to your truck for long periods of idleing.
Now as far as cheaper to idle than start, thats one of those questions that nobodys for sure on, I dont' think you or I would actually notice the savings (if there are any) it would be such a small percentage that it would probably take hundreds upon hundres of thousands of miles to realize any difference.
Just my .02
Just my .02
The Fedex Express trucks run a Cummins with an automatic, and seems like max payload is 6000lbs in those, GVW maybe 16000???? Those are the 700 Cu Ft models. There is a 900 as well. Newer ones have a 5 gear auto.
UPS has some Cummins, or so it sounds, but runs manual trannys. They run a little larger truck on average. Not sure about payload.
Both outfits have a variety of trucks as the order of the day is to run the wheels off them. Some are real penalty boxes....
Both outfits have Sprinters also. Nice truck, but like a doll house compared to the bigger trucks.
It's becoming illegal in more and more states to leave vehicles running unattended.
Why give that cranky officer at 7-11 for first cuppa coffee a reason to give you a ticket?
But more to the point,
Think about driving to the grocery store in your shiny new Power Smoke and running inside for that proverbial six-pack and leaving the truck running.
While you're inside the loser in the lot that watched you come in runs up to your cool truck with a spring loaded center punch and breaks the passenger side window (or the rear window from inside your really neat camper shell) and jumps in and drives away because you so conveniently left him not only the keys to your new truck but also the keys to your house and your address and everything else you left in your truck!
I wouldn't make it so easy for these guys. If you did a hard pull, let it idle at the stop light and drive slow and easy in the parking lot, let it idle a few min and SHUT IT DOWN.
Then lock it and take your keys. The first thing the insurance company asks is "Was it locked?" and/or "did you take your keys?"
Cheers,
Rick
Cheers,
Rick
tjs1992
06-25-2014 12:49 PM
dlbrooks2658
15
12-01-2007 11:24 AM
