1999 diesel engine stops running
Old Nov 28, 2007 | 07:59 PM
dlbrooks2658's Avatar
dlbrooks2658
Started truck and let it warm up, engine shut off, restarted right away, did it again a few minutes later. Once on the road no issues with running but service engine light is on solid now.
Old Nov 28, 2007 | 08:34 PM
badger2196's Avatar
badger2196
Sounds like the classic CPS issue. If you replace it, make sure you get the new (cheaper and better) gray CPS.
Old Nov 28, 2007 | 09:28 PM
Clint40's Avatar
Clint40
Cps it could be OR the UVC harness is apart.
Old Nov 28, 2007 | 09:49 PM
dlbrooks2658
installed a brand new CPS last week
Old Nov 28, 2007 | 10:08 PM
clintbonnie's Avatar
clintbonnie
You really need to have your faults codes read with a scanner compatiable to our powerstroke.. When the SES light is on, does the engine miss like it is running on less than 8 cylinders? This would indicate under the valve cover wiring or connector is bad or loose.. Did you get a new cps from ford or aftermarket?
Old Nov 29, 2007 | 10:10 AM
dlbrooks2658
New CPS from Napa Auto. Engine running on all 8 - plenty of power, just stops like the fuel is shut off when at idle. After driving the truck for 1/2 hour engine no longer shutting off at idle.
Old Nov 29, 2007 | 10:18 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
There have been a few complaints about CPS from Napa. Might look into that.
Old Nov 29, 2007 | 03:27 PM
WonderDonkey's Avatar
WonderDonkey
Napa CPS = Pile of crap, you may have a bad connection on your UVC.
Old Nov 29, 2007 | 06:49 PM
badger2196's Avatar
badger2196
My first CPS replacement was the NAPA component and it died after less than 100 miles.
Old Nov 30, 2007 | 12:05 AM
dlbrooks2658
here are the DTC codes -
#01 - P1211 - ICP Not Controllable
#02 - P0344 - CPS intermittent bank 1/1
#03 - P0603- Internal Ctrl Mod KAM Error
does replacing the piece of crap Napa CPS with the part from Ford fix this?
Old Nov 30, 2007 | 01:31 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Pretty much. Nothing worse than a POS.
Old Nov 30, 2007 | 08:51 AM
dlbrooks2658
thanks again for everyones help. this forum is great...
Old Dec 1, 2007 | 09:12 AM
pminne's Avatar
pminne
Rocky Mountain High
Where is the CPS located?
Old Dec 1, 2007 | 10:50 AM
motionmarineaudio's Avatar
motionmarineaudio
no smoke out of exhaust while cranking. the question is fuel or spark. would there be any codes to check for. could my diablo predator programmer tell me any codes?
Old Dec 1, 2007 | 11:22 AM
clintbonnie
The cps is located on the front of the engine..You can see it if you crawl under the engine, on pass. side front, above the main pulley and near the water pump you will see it.. There is a metal angle bracket attached to the sensor and it is held in with a 10 mm bolt. After removing the bolt, just pry the sensor out, after removing the electrical connector. For more info (bookmark this link) see:
http://www.7point3.com/mods.aspx
The sensor p/n's in the above link are out dated.. Go to Ford and get a F7TZ-12K073-B. It is Grey in color.. Should be less than $30.
