Start-No Start
Old Nov 22, 2014 | 02:49 PM
First Time Diesel's Avatar
First Time Diesel
Start-No Start
So I have a 1995 F250 Powerstroke that recently starting acting up. Wanted to see if anyone else has experienced this.
It will start and run just fine first thing in the morning, but if I shut it off and try to restart it a few minutes later it just cranks and cranks and cranks. If I let it sit for a couple hours it will start right up again and the process repeats. I thought fuel filter but have replaced that with no change in condition. I figure it is fuel or electrical but not sure where to look next.
Old Nov 22, 2014 | 03:10 PM
427 fordman's Avatar
427 fordman
Sounds like the ipr orings. I'd pull it and check.
Old Nov 22, 2014 | 04:08 PM
ProjectDually's Avatar
ProjectDually
Are you getting smoke while your cranking?
Old Nov 22, 2014 | 05:55 PM
fordman67's Avatar
fordman67
X2 .........
Old Nov 22, 2014 | 06:27 PM
First Time Diesel
No, it seems that there is no fuel being injected at all.
Old Nov 22, 2014 | 06:29 PM
First Time Diesel
I talked to a local guru and he said I may be getting one of my fuel lines vapor locked due to heat exposure. Which kind of made sense to me since I know of a small exhaust leak. Is that even possible?
Old Nov 22, 2014 | 06:57 PM
oldbird1965's Avatar
oldbird1965
I doubt it! I'll 3rd the IPR O rings need to be replaced.
Old Nov 22, 2014 | 08:15 PM
First Time Diesel
Thanks for the advice guys. Would this seal kit from Rock Auto have everything I need?
300? 300: true ); height:expression(this.height > 400? 400: true );">
Old Nov 22, 2014 | 09:02 PM
fordman67's Avatar
fordman67
That's it...if you do not have good IPR seals then the hot oil bypasses the IPR.it takes a minimum of 500psi of high pressure oil to operate the injectors. No oil=no fuel...the IPR controlls the pressure of the high pressure side. The ICP gives feed back on how much pressure is being generated and tells the pcm ...the pcm in turn varies the IPR to change the pressure up or down..
Old Nov 23, 2014 | 12:03 AM
First Time Diesel
Thanks Fordman67, that explanation helped me understand how bad seals would give me the symptoms I am seeing!! Now I just need to find me one of those 29mm axle sockets I've been reading about. Thanks again for all the help.
Old Nov 23, 2014 | 07:17 AM
ProjectDually
Well, it looks just like an O2 sensor socket, but this is what you are looking for!
http://www.ebay.com/itm/291167215723?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Amart927
Jan 8, 2015 05:49 AM
trevorrules
37
Sep 3, 2014 02:49 PM
mustangmatt
Oct 6, 2011 02:57 PM
Lubbockguy1979
May 11, 2009 09:05 PM
russp
Jul 11, 2007 02:38 PM
