Sponsored by: Real Truck
front axle
Old Sep 25, 2006 | 06:26 PM
msurovick's Avatar
msurovick
front axle
can anyone tell me where i can get outter(stub)axle shafts for a 99 super duty . the parts stores say its a dealer item , but the dealer says they onle sell the assembly. inner, outter, and ujoint assembled. and for a big buck.only need the outters, even if they are aftermarket. any help would be greatly appreciated
Old Sep 25, 2006 | 08:12 PM
TwelveAlpha's Avatar
TwelveAlpha
There's got to be salvage yards around. I know of several here, and its just a phone and a hope they have what you want. Sometimes they're a great resource. You get a truck that got totaled from a head on collision but the tailgate and rear axle are pristine, there ya go. Actually I sell more to them than I buy. What does a guy do when he has the original mirrors, turbo, or intercooler just soaking up storage space in the garage?
Old Sep 25, 2006 | 08:55 PM
PHWLEE's Avatar
PHWLEE
Where are you located? I have a local guy here that has been working on axles for over 20 years and stocks alot of parts.
Old Sep 25, 2006 | 10:16 PM
msurovick's Avatar
msurovick
in reply to twelvealpha : i need front axle parts: in reply to Phwlee i am in western pa. i havnt tried the scrap yards because usually around here, a person is usually better off buying new parts for most items.let me know if you can help even if there affordable aftermarkets available
Old Sep 25, 2006 | 11:02 PM
John311t's Avatar
John311t
If you are talking about the front outter stub axle, at the dealer there is a part number for just that. When i was doing my front end swap, my needle bearing was destroyed and eat the stub shaft away. So i started looking around here and saw guzzles write up on lubing the front needle bearing. Most of them well tell you it only a whole assembly until you give them that actual part number. Here the number, 4C3Z-3B387-AA.
Old Sep 26, 2006 | 09:42 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You might also be able to get it from a Dana dealer/shop. Try the big truck parts houses, if you have any near you...
And see if there's a Dana number on the stub...
Old Sep 26, 2006 | 05:43 PM
FortyFords's Avatar
FortyFords
On one of our previous post awhile back someone kindly posted the axle stub Ford Part number.
the ford parts place is wrong.Let me see if I can find it.
Rich
Old Oct 3, 2006 | 01:04 PM
msurovick's Avatar
msurovick
Smile
thanks to everyone for the help. I finally found outter axle shafts online @Quad 4x4. they are 117.95 if anyone elese needs to find them please let them know. its a far cry from the 1250.00 the dealer wants for a pair of the complete set
Thanks All
Old Dec 30, 2007 | 07:24 PM
GregA's Avatar
GregA
Originally Posted by John311t
...needle bearing was destroyed and eat the stub shaft away....Here the number, 4C3Z-3B387-AA.
Same problem here. Anyone know if this is the correct number for the '00 Excursion 7.3 as well? - GA
Old Dec 30, 2007 | 08:33 PM
rudedogii's Avatar
rudedogii
DANA parts
I have a 2000 F-250 V-10. I broke the front drivers side axel at the carrier.
I shopped around for one , dealer was to pricey, and salvage yards only sold complete axels.
Then I found the complete drivers side axel (inner and outer) on E-bay for $100.00 plus shiping.
Later I found out the carrier was also damaged and needed to be replaced.
In the end I must have spent around $1500.00.
One used axel, new carrier, Lock-Right locker, bearings, seals, 4:88 gears front and rear, plus labor.
Old Dec 31, 2007 | 04:32 PM
GregA's Avatar
GregA
Local Ford dealer had in stock the stub axle (4C3Z-3B387-AA) and the u-joint (F81Z-3249-AA). About $210 out the door. Parts fit the '00 Excursion fine and will soon be on their way back to work... - GA
Bennyboy2002
Jun 15, 2010 07:51 PM
hayden01
Dec 4, 2008 07:25 PM
stealth1
Mar 30, 2008 06:58 PM
Broncoguy89
Jan 28, 2008 11:54 AM
JOE-M
All Things Towing
Mar 20, 2006 11:15 PM
