I have a 1987 f-150 with a bad u-joint on the right side axle shaft (outter one) i currently have the front end tore apart and can't get the axle to come out of the diff. from what i'm reading in the manual it should just pop out. it seems stuck i can move it in and out about an 1/8". any ideas?
yes passenger side. I was acctually thinking of replacing both joints seeing as i have it apart and it is my plow truckso it will get abuse. i didn't remove the clamps on the slip joint because i was hoping to get the whole shaft out. but if i can't pull the axle from the diff i will just put the outter joint in cause the inner one isn't sticky
