FT engine pull
Old Sep 25, 2006 | 10:53 AM
jetfixer's Avatar
jetfixer
FT engine pull
I'm trying to get my 330 ft engine out of my truck and am having problems. I have removed 4 bolts connecting the bell housing to engine which is all I can see, But I can't get it apart. The tranny is a 5 speed. Am I missing something totally obvious? I've got manuals coming but I was trying to get this pulled asap. Thanks for any ideas. 1972 F600
Old Sep 25, 2006 | 10:58 AM
FalconStng's Avatar
FalconStng
I may be wrong but I think there should be 6 bolts between the engine and bell housing.
Good Luck!
Tracy
Old Sep 25, 2006 | 11:51 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Did you take out the starter? (dumb question).
Old Sep 25, 2006 | 11:57 AM
jetfixer's Avatar
jetfixer
Yeah, I 've got the starter out. I may be like Mr Magoo, but I cant see any more than 4 bolts on the bell housing. Anyone know the locations of the bolts for sure? Thanks
Old Sep 26, 2006 | 02:40 PM
bchitwood73's Avatar
bchitwood73
Try jacking up the front of the trans near the bell housing and pulling up, and out at the same time. If its anything like my 390 the motor mount studs will not cleat the frame unless the engine is off by at least 3'' and at that angle your trans main shaft is probally binding inside the clutch. You may also have the two dowles on the sides of the bell housing binding which will stop you dead in your tracks.
Old Sep 26, 2006 | 03:13 PM
Redmanbob's Avatar
Redmanbob
Did you remove the four nuts from the torque converter?
Old Sep 26, 2006 | 03:14 PM
bchitwood73
Unless he means a 5 speed auto there should't be a torque converter involved.
Old Sep 26, 2006 | 11:45 PM
jetfixer's Avatar
jetfixer
Update: I found two more lower mount bolts, thanks to a hint from one of the other forums. It damn near jumped out of the truck when I hooked up the chain hoist. Thanks for the input.
Old Sep 27, 2006 | 09:29 AM
krewat's Avatar
krewat
Go Magoo!!!!
Just kidding
M Frank
Sep 5, 2011 05:48 PM
defyrftr
Apr 8, 2009 01:44 PM
Rwing21
2004 - 2008 F150
Apr 7, 2008 09:54 PM
elliott
Georgia Chapter
Mar 11, 2003 09:35 PM
Viskase1
All Things Towing
Dec 2, 2002 07:21 PM
