Sponsored by: Real Truck
abs light
Old Sep 25, 2006 | 09:36 AM
donald burnash's Avatar
donald burnash
abs light
03 excursion abs light comes on and goes out, no codes at first. Eventually a c1185 internal power relay code will set. Pinpoint test pointed to control module, but after replacement light still comes on. Now the light only comes on under semi-hard acceleration, setting in park or taking off from stop. The light will come on for a couple of seconds and then go out. Doesn't matter what time of day or temp. Can someone help?
Old Sep 25, 2006 | 09:52 AM
Pocket's Avatar
Pocket
Did you check the wiring harness going to the control module? Also is it still throwing the same C1185 or a new code?
Old Sep 25, 2006 | 10:53 AM
donald burnash
Wiring is ok and there are no other codes. Actually the c1185 code takes a while to set. Removed the belt to rule out alternator, no difference.
riotstick
2009 - 2014 F150
18
May 13, 2017 01:42 PM
mattswabb
Escape & Escape Hybrid
May 3, 2015 04:09 PM
Epd444
Aug 14, 2013 04:43 PM
boot2
Jun 26, 2012 05:33 PM
StorminTexan
3.8 & 4.2L V6
Jul 16, 2004 07:55 PM
