mustang problems...
Old Sep 25, 2006 | 05:02 PM
Miller's Avatar
Miller
is that the same as the IAC on the throttle body?
Old Sep 25, 2006 | 08:21 PM
Miller's Avatar
Miller
i disconnected all 4 o2 sensors and changed the fule filter, it does not die any more and seems to be running not as rich, the car has good fule pressure, could the pump still have gone bad? also, the car should run ok with the 02 sensors disconnected right?
Old Sep 25, 2006 | 09:23 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The IAC is on the throttle body.
One thing at a time... reconnect the O2 sensors and see if the fuel filter had something to do with it (doubtful).
With the O2 sensors out, the computer is running in open-loop. It doesn't care about lots of sensors, it's just doing the best it can with what the engineers put into it.
So, disconnecting the O2 sensors didn't solve the problem, it just made the computer ignore lots of other things. It's probably not the O2 sensors, it's something else, you just made the computer not care about it
Old Sep 26, 2006 | 01:17 AM
Miller's Avatar
Miller
well i have already replaced the IAC, and that was not the problem..looks like its gonna have to go to the dealership
Old Sep 26, 2006 | 06:08 AM
dk5122's Avatar
dk5122
I love it. Ford truck website. You guys help a member with a Stang. This is why I always search FTE first when I have a problem with one of my vehicles. Great job guys keep it up!
Old Sep 26, 2006 | 08:15 AM
krewat's Avatar
krewat
Before you go to the dealer, did you change any of the temperature sensors?
Sounds like the computer is keeping rich thinking the motor isn't warmed up.
If you had a scan tool, you could check what the computer THINKS is the coolant temp.
Old Sep 26, 2006 | 12:04 PM
Miller's Avatar
Miller
no i have not changed any of the temp sensors, and i do not have a scan tool
Old Sep 26, 2006 | 12:55 PM
krewat's Avatar
krewat
Find a local garage that can do it, or Autozone does free scans (not sure if they will read the temp for you).
Get it fully warmed up and take a trip to the local mechanic and see if they can scan it for the current coolant temp. If it's way off, that's the problem.
mustang9701
Feb 11, 2017 04:29 PM
Fifty4F100
Nov 7, 2016 06:49 PM
smokeyjo50
Apr 1, 2015 04:30 AM
DADDYFATSAX
Aug 2, 2013 12:54 PM
1yamman350
May 9, 2004 08:15 PM
