I'm doing some research and according to other posts that number is the engineer's number (related to part number by changing the F to a A). Let me know if I am really wrong.
Well, sometimes Ford finds some "ENHANCEMENTS" to add in. Read: it fixes an oopsie. that or you might have gotten a new PCM and so it is programmed to the latest specs. I have an 01 that I got reprogrammed to the latest file. Didn't notice much of a change. Switched to a DP Tuner programmed unit
I've got a hole drilled through my DLC (diagnostic link connector) under the dash and a small padlock run through it to keep any unwanted "spam" coming into my PCM. The truck runs fine and if it ever needs to go to the Ford dealer to have something fixed (that I can't here at the Chevy shop), they will have to ASK me for the key....and no reprograms, thanks. I've heard way too many horror stories from 6.0L owners about "flash updates".
