Aftermarket Tuner & Defuel Settings
So I just purchased the Edge Platinum Tuner, and man does this thing rip! I cannot believe the difference. My question is in regards to the Defueling during shifting. This is not Tuner specific, so anyone with any tuner that has defueling please chime in. My question is, I was set at 100% defueling under extreme mode. WHenever I change it to lower than 100% it suggests a transmission upgrade or something like that. What % defueling is safe to run all the time? I adjusted it to 70% and that made a huge difference. However the delay in the shifts still bothers me. Please help. Thanks in advance
Dan
Dan
I have the seven levels on my Banks system. I don't have the unit in front of me now, but I believe
-level 1 is 100%
-level 7 is 50%
levels 2-6 are staggered in between.
Defueling just doesn't blend with the muscle car way of thinking.. but I never at 600+ lbs of Torque either...I like my tranny more than I like to Bark.
-level 1 is 100%
-level 7 is 50%
-level 1 is 100%
-level 7 is 50%
-level 1 is 100%
-level 7 is 50%
Seriously I cannot get enough of the truck now. Its like an entirely new monster.
And is everyone with a tune running an intake? I havent uprgaded intakes yet. I have a 4" turbo back catless MBRP exhaust on there that sounds amazing!
Thanks again
Originally Posted by 6L PWR
Until I put in the new torque converter I kept mine at 100% all the time. The shifting wasn't all that bad as long as you set it to firm shifts. Have you done that under the Transmission Control menu?
Originally Posted by LaxPlaya21
I have it set to firmer shifts under 90% load. I think I need to spend some more time with the manual to figure it out. What type of converter did you get? Is it just heavier duty? How much? And how difficult to install? After you did that could you run it at 0% defuel? Thanks for your help
84 f250 6.9
18
01-25-2011 06:05 PM
05 f250 6 inch lift
10-26-2010 07:51 AM
