Speedometer Cable
Old Apr 2, 2001 | 12:38 PM
ebayer's Avatar
ebayer
Speedometer Cable
My Speedometer cable jumps, I am new at working on my truck because I am only 16, but I wanted to know If I could do anything about the jumping of the needle. I also have no lights on my speedometer and gas gauge and temp. gauge any help would be appreciated Thanks.
Eric J. Bayer
Old Apr 2, 2001 | 03:39 PM
davlo's Avatar
davlo
Speedometer Cable
Eric. when I have that speedometer problem I take off the cable and work some liquid graphite down inside. Its just sticking.your lights if they are all out, check bulbs, grounds and connectors.
Old Apr 2, 2001 | 03:59 PM
jimarlie's Avatar
jimarlie
Speedometer Cable
Eric. Sounds like the speedometer cable needs greasing. As for your dash light problem, my first quess would be a burned out fuse. Check your fuse box under the dash. jimarlie
Old Apr 2, 2001 | 04:32 PM
66 custom cab man's Avatar
66 custom cab man
Speedometer Cable
dittos on the cable. Re: dash lights - check headlight switch, if the dimmer part is bad you wont have lights.
Old Apr 2, 2001 | 08:58 PM
jimarlie's Avatar
jimarlie
Speedometer Cable
I-6 Power
Nov 28, 2012 07:51 AM
Bayer-Z28
Nov 26, 2009 07:28 AM
mudslinger1987
1983 - 2012 Ranger & B-Series
Nov 9, 2004 09:12 PM
ebayer
Mar 31, 2001 04:21 PM
ebayer
Mar 29, 2001 08:35 AM
