Vin decoding gears
Old Sep 18, 2006 | 07:45 PM
Vinford's Avatar
Vinford
Vin decoding gears
I was wondering if anyone here can tell what gears I have in my 79 by the vin number?
If so heres the vin # and a thanks ahead of time!!!
05/ 1979 F-250
4spd Reg cab 4x4
Vin # F26HPFA7167
Old Sep 18, 2006 | 08:29 PM
Mil1ion's Avatar
Mil1ion
No, it's not in the VIN#...
The Axle ratio code is on a special part of the rating plate on the door.
see this page of mine.. first the top for the location (Position 12)...then near the bottom for the de-coding.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Sep 18, 2006 | 08:33 PM
Vinford's Avatar
Vinford
I wasnt sure about the tag on the door as the door might have been changed but it might not of either.
The other tag was on the cab.
Ill go look at door tag.
Thks
Old Sep 18, 2006 | 08:34 PM
Mil1ion's Avatar
Mil1ion
There may still be a axle Ident tag attached to a differential mounting stud with the proper info on it ?
Old Sep 18, 2006 | 09:20 PM
Vinford's Avatar
Vinford
Axle 24
Trans K
F264
Does any of that mean anything?
Old Sep 18, 2006 | 10:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can decode those on Mil1ions site or here:
http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
Old Sep 18, 2006 | 11:05 PM
Vinford's Avatar
Vinford
It came up as saying the truck had a v8 and a automatic.
The truck has a 6 with a 4spd?
Tag on the door and the cab has the same vin number?
Old Sep 19, 2006 | 11:03 AM
Mil1ion's Avatar
Mil1ion
Code 24 = Dana 60 - 4.10 Ratio
Trans K = Automatic = C6
VIN# contains engine code
F26HPFA7167
F26- F250 4x4
H= Engine code = 351M
P = Plant build code = Twin Cities
FA7167= Consecutive build number
F264 - Pickup code for axle weight spec = w/7400 lbs
cndfarm99
21
Oct 11, 2014 04:34 PM
Itsme7
Jan 3, 2011 09:22 PM
GreenMonster32
Feb 4, 2009 07:25 PM
78bigunns
Jul 29, 2008 03:46 PM
trouble
Aug 17, 2002 11:41 PM
