Where does backup light switch mount (NP435)?
Old May 28, 2001 | 08:02 AM
Charles-65F350's Avatar
Charles-65F350
My truck has no backup lights and I want to add them. It has the NP435 manual transmission. I have looked all over it and cannot find any place to install a switch. Did the early ones not have this provision, and can I drill/tap a hole somewhere to add one? thanks.
Old May 28, 2001 | 09:35 AM
6t6merc's Avatar
6t6merc
The switch is in the top cover on the later transmissions. Your best bet is to swap a later cover onto yours.
Eric
Old May 28, 2001 | 01:09 PM
jowilker's Avatar
jowilker
Charles, It could be just as simple for you to toggle switch them in. I know it would be cool for it to be automatic, but a under the dash toggle switch could be a lot easier to install.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old May 28, 2001 | 09:58 PM
Rwhistles's Avatar
Rwhistles
Charles,How are you comeing on that 5831 install. would like to hear more about it.Ive had that same idea for some time after seeing a new ford diesel with one in it.Glad you broke ground first.
Robert
Old May 28, 2001 | 10:18 PM
whomrig's Avatar
whomrig
The toggle switch is a good idea. you gotta remember to flip it though. If you go with the toggle switch, install a light in the dash so you know when the b/u lites are on.
Wayne
e-mail
http://home.pacbell.net/whomrig
Old May 29, 2001 | 09:49 PM
66ranger's Avatar
66ranger
Am currently using a toggle switch for my automatic.BUT, when my '66 was a 3-speed, a long L-bracket was mounted on the fenderwall with a momentary button switch attached thru a drilled hole at the bracket end. When the truck was shifted into reverse, the linkage would press this switch, lite the lights (aftermarket type, mounted in rear where the optional factory reflectors went) and of course turn the lights out when linkage was moved. An easy,cheap solution to avoid the dash toggle......
Old May 30, 2001 | 07:48 AM
Charles-65F350
Rigging a linkage would be nice except for one major problem - the shift mechanism for the NP435 is completely contained within the cover. I suppose I could run a string from the shift lever to a switch Anyone got a later-model cover they don't need?
Old May 30, 2001 | 10:26 AM
6t6merc's Avatar
6t6merc
The cover you need is easy to find - probably more common than the one without the switch - and cheap, if you keep your eyes peeled. I found one on a loose trans in a scrapyard and got it as a throw-in. I might use it eventually, but didn't put it in just yet because I know the shift rails etc in the one in the truck are excellent. The cover I got was on a Dodge trans.
Eric
Old May 30, 2001 | 10:32 PM
dinosaurfan's Avatar
dinosaurfan
petrovich79f250
Dec 19, 2020 09:37 AM
Lilyhy
2014+ Transit
Apr 13, 2016 07:19 AM
Mountainburd
16
Feb 4, 2016 10:25 AM
Jageesey1
Dec 23, 2015 03:08 PM
