1 wire alternator
Old Sep 15, 2006 | 06:39 PM
Ricke9590's Avatar
Ricke9590
1 wire alternator
I was looking for a 1 wire alternator for my f-100 (429 bb). Cant seem to find any, any suggestions? Any way to make a GM 1 wire work?
Old Sep 15, 2006 | 10:14 PM
Ford_Six's Avatar
Ford_Six
To use a one wire, you have to remove the voltage regulator, an I would replace the fusible link wire with an 8ga or 6ga wire, and a 175a megafuse right by the battery in case there is a short. Your ammeter won't work with a one-wire setup. As far as fit, I think Mean Green makes a one-wire alternator that fits the Ford brackets, but it's pricey. I'd check the fit of a standard GM style one wire unit, and see what kind of mods it will take to fit. You can probably pick up an example one for fitment from a junkyard for $25 or less.
I am doing a similar mod on my 72, but i won't really be much help for fitment issues- I am using a larg-frame Delco alternator, rebuilt to provide 250a, to help keep up with a winch. It'll be a custom mount, intergrated with a power steering pump mount, and no adjustability at that point.
Old Sep 16, 2006 | 12:31 AM
Ricke9590's Avatar
Ricke9590
From what I can see on the GM models (big block) the ears seem to be the same, I am goin to pull mine tommorrow and do some measurements to make sure, the only Issue I can see righit now is correct turning directions and maybe how far the pully sticks out, I dont want a bunch of shredded belts.
Old Sep 16, 2006 | 08:31 AM
dcapshaw's Avatar
dcapshaw
Summit racing sells 1-wire, Ford compatible alternators. I just put one in my '69 small block. It was a very easy upgrade.
Dan
Old Sep 17, 2006 | 07:43 AM
Dave Severson's Avatar
Dave Severson
Summit, Jegs, and a ton of different suppliers on eBay....
Old Sep 17, 2006 | 12:04 PM
Ricke9590's Avatar
Ricke9590
Ive noticed this, but all I can is small block ford, I called summit and they said it would take over 2 weeks to get one because its a non stocked item...... ill get one eventually.
77 Bronco
1966 - 1977 Early Broncos
Jan 16, 2015 11:41 PM
mtntop1
Apr 24, 2009 05:40 PM
SwOkcOffRoader
Jul 4, 2007 07:03 PM
medicpg
31
May 20, 2003 09:55 AM
