Sponsored by: Kumho
Steering System
Old Sep 15, 2006 | 06:49 AM
Chumbucket's Avatar
Chumbucket
Steering System
How to bleed system after installing new gear box ,hose's ect?? Thank's
Old Sep 15, 2006 | 07:53 AM
jtmerritt's Avatar
jtmerritt
Air will bleed out on its own over time but if you want to get it out quicker, then get yourself a new power steering reservoir cap. Drill and tap a hole in the old one big enough to screw in a small brass or nylon barb. Put the cap on the reservoir and attach the vacuum pump with some clear plastic tubing and pump just until you start to see fluid trying to come up through the plastic tubing. You should have most if not all of the air out.
John
DSparksF250
Oct 30, 2016 10:47 PM
lakedweller
6.7L Power Stroke Diesel
13
Apr 29, 2011 02:57 PM
byoungquist
Exhaust Systems
Nov 29, 2010 01:22 PM
wml
13
Mar 18, 2009 03:47 PM
