fuel starved
Old Jul 14, 2001 | 08:18 PM
cuttinwood's Avatar
cuttinwood
fuel starved
Just put a new fuel pump on my '63 223, new fuel lines and filter. Now when I get up to speed and accelerate I bog out and sputter. It acts like I'm running out of fuel but I've got the recommended pressure at the carbuerator. Any ideas?
Old Jul 14, 2001 | 09:20 PM
whomrig's Avatar
whomrig
fuel starved
Maybe some little peice of dirt got in the carb? I had a similar experience with mine, and needed to clean out the float chamber.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 15, 2001 | 11:49 AM
64 f100's Avatar
64 f100
fuel starved
If you have an old rubber fuel line somewhere in the system, these will sometimes colapse under the suction. You might check the lines, don't forget the one under the cab.
Rich
Old Jul 15, 2001 | 12:37 PM
huitt24's Avatar
huitt24
fuel starved
Hey check the post "Fuel starvation problems in a 390" I just went through this with my truck and I believe I have a cracked pickup line in the tank not sure but I think I am positive. Check it out it may give you some ideas.
Jack
66 F250 Camper Special 390
Old Jul 15, 2001 | 08:39 PM
Rosati's Avatar
Rosati
fuel starved
You mentioned you replaced the filter, that's good. But was it the right filter and did you install it correctly?
Most filters are one way and should be marked as to the direction of flow.
Like 64 said, the lines may collapse but you said you replaced them...did you get them all tight? I had the same problem with my 1964 Pontiac Bonneville after replacing the carb. Turns out I reversed the filter (inline type with a check-valve) and was also sucking air around several rubber hose to metal connections.
Good luck and let us know how it turns out.
Krosati
Old Jul 15, 2001 | 11:07 PM
cuttinwood's Avatar
cuttinwood
fuel starved
Yep replaced all rubber too. Fuel filter same kind as original w arrow in right direction. Have afeeling from all this its in the carb called a buddy who's good at them to take a look. Thanks for the tips. Hopefully this has narrowed it down.
Old Jul 19, 2001 | 10:48 PM
cuttinwood's Avatar
cuttinwood
fuel starved
Wayne thanks for the tip!! Turns out it was trash in the float chamber. That and the float screen. (clogged)
Old Jul 20, 2001 | 06:04 PM
themred66's Avatar
themred66
fuel starved
srqdiesel chef
Feb 14, 2014 09:32 AM
banicman
Nov 26, 2012 12:36 AM
va150
Jan 23, 2011 10:04 PM
Mr. Badger
Jan 12, 2011 06:44 PM
terryq
2004 - 2008 F150
Oct 31, 2010 07:41 PM
