front windshield installation
Old Sep 12, 2006 | 05:58 AM
sonofa75's Avatar
sonofa75
Question front windshield installation
hey fellas
got a question is there a easy way to install the front windshield on a 75 ford truck, I have the new rubber seal. Also this truck has a sliding rear window and the frame is loose on the sliding part is there a rebuild kit for that???
You all have helped me alot on my sons truck and i thank you!!!
Old Sep 12, 2006 | 08:39 AM
fp_5's Avatar
fp_5
Installing the windshield is not that difficult. There was a post on here way back with some pics, I'll see if I can dig it up. Tech article explains it more detail...
https://www.ford-trucks.com/article/...ord_Truck.html
Essentially, you use a rope, some lubricant like soap or silcone spray. Install the rubber gasket onto the glass. Run a rope along the top and side channels of the rubber. Use lubricant on the rope and in the gasket channel. Lift the windshield into place and seat the bottom off it into place. Now from the inside of the truck carefully and slowly pull the rope up evenly on each side ane the windshield and gasket will slowly seat itself as you progress up the side and across the top. BTW, if your windshield has SS trim, install it FIRST! before you install the windshield.
I'm not sure about your rear slider? You maybe better off replacing it with a new or used one. There is not a lot of clearance in those pieces to make a repair.
Frank
Old Sep 12, 2006 | 10:26 AM
fp_5's Avatar
fp_5
Found my original post on this.....
https://www.ford-trucks.com/forums/3...d-r-and-r.html
and some good pics from Ken S....http://pg.photos.yahoo.com/ph/moonl...e2000/my_photos
Old Sep 12, 2006 | 10:34 AM
sonofa75's Avatar
sonofa75
thanks i'll give it a try.
do I need to use rubber sealer in corners of frame or were the rubber gasket meets??
Old Sep 12, 2006 | 10:46 AM
fp_5's Avatar
fp_5
I didn't need any with a new gasket. Some people do recommend that you use some in the corners. Make sure you buy urethane sealer.
Frank
Shane in WI
24
May 20, 2016 08:40 PM
NW 150
13
Sep 22, 2013 06:58 PM
5 Star
1947 and Older Ford Trucks
Aug 30, 2013 03:55 PM
bucks77ford
Feb 5, 2008 07:21 PM
JnJO39
Jul 13, 2005 12:18 PM
