1978 - 1996 Big Bronco
E4od Trans 1990 Help
Old Sep 11, 2006 | 03:20 PM
pnuthull1990's Avatar
pnuthull1990
Question E4od Trans 1990 Help
How Can I Identify A E40d Trans In Another Vehichle.mine Is A Jasper Trans And Has No Tags And Will A Aod Trans Work Help Me Thanks I Have A 5.8 L 351 1990..
Old Sep 11, 2006 | 10:05 PM
greystreak92's Avatar
greystreak92
The E4OD is huge compared to any of the other autos used in the F-series and Bronco. It also has no separate bellhousing. The bellhousing is cast as part of the trans. case. The AOD will bolt up but you will need the TV cable setup for shift control and (even though I'm gonna get arguements) you really should swap the computers because the ECA for trucks equipped with an E4OD while they will still run the engine, they will operate in "limp mode" which limits the performance parameters available to the system.
Old Sep 12, 2006 | 10:17 AM
helirich's Avatar
helirich
You will also need to change driveshafts. And the geometry on the front suspension will not match the front driveshaft. I dont know if this is a major problem.
cnacowboy
Aug 10, 2010 08:16 PM
Rlknight1
Aug 30, 2009 03:01 PM
Catch
Dec 31, 2008 08:15 PM
pnuthull1990
Sep 10, 2006 11:03 AM
Bill Roach
Jun 14, 2004 07:57 PM
