Brake Controller - Which One Do I want??
Old Sep 15, 2006 | 02:03 PM
expy98's Avatar
expy98
had a Jordan controller and now a Prodigy. The Jordan had just one adjustment **** so it was very simple and worked great. My only complaint was the mounting location is somewhat limited due to the cable that connects to the brake pedal. Got tired of bumping into it w/ my knee. Jordan says he'll have a remote display model next year. I couldn't wait and so far, Prodigy is fine.
Old Sep 15, 2006 | 04:04 PM
diesel_dan's Avatar
diesel_dan
BeachBumCook: I've had at least 5 different controllers and the Prodigy is the best (but I haven't had much time with the integrated one in our new SD yet, which, btw, I bet Tekonsha makes for Ford ). I also second the comments on the boat trailers and surge brakes -- it's been my experience with all my boat trailers large enough to have brakes -- they've all had surge style.
Last: eBay has the best prices for Prodigy hands down. Bid on one that will come with the Ford factory wiring harness and your installation will literally be a snap (connector) and mounting the unit.
Good luck and have fun with that new boat! (I vote for the runabout, btw, unless you have serious skier/wakeboarders in mind -- been there too)
Old Sep 15, 2006 | 07:03 PM
SMrGee's Avatar
SMrGee
Prodigy is an outstanding brake control. I have used one for 4 years and have been very pleased in all driving conditions, and I tow a 31 foot, 12,000 travel trailer.
Old Sep 17, 2006 | 05:31 PM
NewXer's Avatar
NewXer
I've been using the Prodigy for 4 or 5 years now. I mounted it low on the dash where the "cage" makes it relatively easy to remove when I'm not towning (I don't store anything in the X that I don't want stolen).
Quick & easy to adjust. I've been grateful for it twice (both times on the way to camp) and the trailer stopped nice & smooth in a straight line behind my X.
Have a buddy that had a Valley that went bad after a year's use, and another that had a Draw-tite burn out on the 2nd use.
Old Sep 17, 2006 | 08:49 PM
Fountain38's Avatar
Fountain38
I installed a Brake Smart controller in my Ex this summer before towing our 30' travel trailer out to Wyoming/Montana. I wanted to have absolute confidence in the mountains, and did not feel that way about my prior unit.
The Brake Smart does tap directly into master brake cylinder, which tells the controller how much pressure to apply. At the same increment/pressure that you are applying to truck. Install was quite easy, do not sweat it. Just pull plug from master & screw this in. Was not cheap, but neither was my rig, and my families safety is worth it to me. Dave
kell104
Jan 11, 2009 05:06 AM
Bsimmer3000
2009 - 2014 F150
20
Dec 14, 2008 08:36 PM
lud04X
All Things Towing
13
Mar 23, 2008 07:57 AM
Beachbumcook
Sep 11, 2006 06:47 AM
BlueJay40
May 1, 2003 07:50 PM
