Bringing my Explorer back from the dead
I have a 72 Explorer with a 360 and C-6. It has been sitting for over 5 years now, I have been living out of state and Dad didnt start it regularly like he said he would. I am now moving back to the area and want to get it going again. I was in last Thanksgiving and had the carb rebuilt, but was not able to get it started. In the last week, I have replaced the fuel filter and ran most of the old gas out of the line and replaced the points and condenser. Still no luck, even with a fully charged battery, until I started playing with the points. I adjusted them, and it started right up. I had it to where it was idleing by itself and everything! I tried to move it and it died a few times, but started right back up. Now, its dead again and no luck. When its cranked, it goes real slow like the battery is low, but the charger says the battery has a full charge. Ive tried adjusting the points several times but no luck. (I know there is a certain gap they are supposed to be set at, maybe thats the main problem). And, the few times it died, it cranked real slow but did turn over.
What should be my next step? Seems to me that there is something not adjusted right, since the old motor cranks so slow even with a fully charged battery. Keep in mind I dont want it running to start driving her again right away, I am just trying to get it to where I can get it up on a trailer and take it to my new place. If I can get it over there, I will have the time and ability to go through and replace all fluids, do a proper tune up, etc...
Thanks for the advice!
If the engine is cranking really slowly on a full battery, you may want to have the starter checked at an auto parts store, and replace the cables. If the starter is drawing too much current, then it is possible that there isn't enough juice left over for spark to make it run. Another thing to look at is if the spark is too far advanced, then it can cause the engine to drag against the starter. You can check for this by disconnecting the power to the coil, and try cranking it. If it cranks quickly, then turn the timing back down a little bit until it will start, then set it at ~8º BTDC with the vacuum advance line disconnected and plugged.
I was thinking about the starter...I went out and bought a new solonoid and voltage regulator, figured they were cheap and it wouldnt hurt to replace. It started right up and seemed for a while everything was better. I was able to stop and restart it several times. But, if I let it sit for more than 15-20 min, it does the slow crank thing again and at that point it may or may not start.
I will check the timing on it like you said by disconnecting the coil and trying it. To turn the timing down, I would have to turn the distributor right? Which direction will turn it down? I will try that first, I have replaced many a starter on that truck, not my favorite job. Is it possible that the starter will draw too much even with a new solonoid?
i am out of town now, but will try the coil thing next time!
took it to the shop and had it tested, and sure enough, the bushings were bad so the brushes were spinning crooked inside the thing. He had it redone in 10 min, charged me 20 bucks (for the rebuild and a new housing end) and i was on my way....
the old thing turns over a lot faster now, and i am more confident that i can get it off the trailer, so it got loaded up tonight, and will go with me to my new place tomorrow. going to be in a nice garage so i can get it running right again. cant wait!
(although i couldnt resist the urge to drive it around town a little today....smoking and sans insurance, but what you going to do??)
thanks for the advice, this is a great site!
Hey there....made it to OKC, and have a question. I took the truck in (well, had it towed after it finally gave out completely) for some work. Among other things, they replaced almost the entire fuel system...lines, fuel pump, and accelrator pump. They also did a tune up including plugs, wires, cap, rotor, points and condenser. They told me I needed a new carb, but I wasnt going to pay for that since Ive done it before. I couldnt even get it home....idled ok, but died as soon as I touched the gas pedal. I just put in a new carb and fuel filter, and still the same problem! I can start it and it idles, and if I baby it while parked I can rev it up pretty good, but pulled out of the driveway and started down the road and trouble. Almost didnt get it back to the house...only made it a block or so down the road. Got it back to the driveway, and it idles great and can rev it up pretty good, but only in park or neutral. With a new fuel and ignition system, what else is there to replace? Can that carb be out of adjustment from the factory? I had to turn up the choke to get it to start, but then turned it down some before I drove it. Think that is the problem? Would dialing it more lean help? The last time I replaced the carb, the truck ran like a bat out of hell!
Sometimes on these old trucks the ignition wiring sustains cracking and become brittle causing the strands to faulter. I suggest to inspect all the wiring to the distributor in close detail to verify is is all good.
What happens is any major movement in the engine or truck causes the wire to Lose contact ...then when trying to start..it regains contact ..only to become loose again.
There have been over 20 people this last year in the 73-79 forum that have had this problem figuring it out after spending $$$$$$$ on parts.
