Headlight wiring
Old Jan 13, 2013 | 06:09 PM
mjtpolice76's Avatar
mjtpolice76
Headlight wiring
My headlights don't come on sometimes but when I move the tilt wheel they start working. I probably have a worn wire in the steering column. My question is what color is the wire that controls the headlights, so I can narrow my search down alittle. What is the best way to remove the plastic around the column.
Old Jan 13, 2013 | 06:15 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
My advice, forget the wire color and just open it up. If one is wearing (and they do that) there could be others. Just go in and fix the whole thing.
Old Jan 13, 2013 | 08:13 PM
landmobile's Avatar
landmobile
You didn't say the year of your truck, but here's a headlight wiring diagram from my 99 service manual:
Looks like the headlight (low beam) wires going through the steering column are red/yellow and red/black. Hope it helps.
Chris
Old Jan 14, 2013 | 09:06 AM
BillyBob69's Avatar
BillyBob69
What A/Ox4 said. These trucks are known for rubbing and breaking wires at the top of the steering column.
Disconnect your batteries so you dont have to listen to the chime
Put your key in the ignition and turn to START but dont start the engine.
Look at the under side of the steering column just near the steering wheel..about 4 or 5 inches and you will see a little hole. In there you will see what looks like a small steel ball. Using a small phillips or something similar, push it up and pull the ignition tumbler out.
Then remove the 3 phillips screws on the bottom of the column and the housing snaps apart.
Tilt the wheel down and pull off the top half of the column. You will see the wiring there for inspection and repair.
Old Jan 14, 2013 | 11:02 AM
mjtpolice76
This was the info I was looking for thank you billybob69, and Landmobile I will keep you updated on what I find, thank you again.
Old Jan 14, 2013 | 11:30 AM
BillyBob69's Avatar
BillyBob69
Only need to remove the ignition tho if you are going to remove the bottom half of the column cover. This isn't needed if you are only removing the top half. Sorry.
I think. Trying to remember now which half the ignition is going through. Pretty sure its the bottom.
Old Jan 14, 2013 | 11:52 AM
PaysonPSD's Avatar
PaysonPSD
Unfortunately you need to remove the lock cylinder to get the top half of shroud loose.
There are some instructions by Ken (woodnthings) at this LINK. Browse down a bit and you will see lock cylinder removal.
Old Jan 15, 2013 | 08:43 PM
mjtpolice76
Just an update to the people that helped me. Took the steering column apart today. There were not chaffed wires the main plug gray in color on the top of the column was loose. So I pulled it out and bent the locking clips out a little bit so it clicked in a little tighter. Thanks for the help.
19stevo88
May 17, 2019 02:38 PM
hanna5120
Dec 1, 2015 12:32 AM
Intimnasc
Aug 10, 2012 03:14 PM
bigblockford_390
Sep 6, 2008 08:56 PM
black58
Apr 22, 2008 09:23 PM
