brake drum specifications
Old Sep 9, 2006 | 08:26 PM
trsshh's Avatar
trsshh
Can anyone tell me the original front and rear drum diameters on 1965 F-100 2WD Pickup?
Some of the earlier model car drums were .030 over 11 inches; but I do not know if these were.
I can not find any specifications on pickup trucks.
Thanks,
Old Sep 9, 2006 | 08:32 PM
jowilker's Avatar
jowilker
trsshh, I can't help you but I want to make sure that you get a proper welcome to the Nations Truck Stop
I hope you will find a place here and join in.
John
Old Sep 9, 2006 | 08:35 PM
trsshh's Avatar
trsshh
Thanks for the welcome.
Sandra
Old Sep 9, 2006 | 09:00 PM
thefonz#1's Avatar
thefonz#1
I'll give you the info I have. The book I have is from 1965-1986 but only gives the drum diameter back to 1977. For this model it has 11.03 and for machined oversize 11.09.
In addition to this, the book also says;
The maximum diameter of the braking surface is shown on the inside of each brake drum
The maximum braking surface diameter specification, which is shown on each drum, allows for a 0.060 in. machining cut over the original nominal drum diameter plus 0.030 in. additional wear before reaching the diameter where the drum must be discarded.
Hope this helps!
Old Sep 9, 2006 | 09:05 PM
trsshh's Avatar
trsshh
It is not anywhere posted on these drums.
Thanks for the help.
sandra
Old Sep 9, 2006 | 10:22 PM
airharley's Avatar
airharley
Using Autozone's specifications chart 10 inch drums are allowed 10.060 max. 11 inch are what thefonz#1 said.
Old Sep 10, 2006 | 05:53 AM
trsshh's Avatar
trsshh
thanks for the info,
I have 11" drums and no data is stamped on them.
Sandra
Old Sep 10, 2006 | 09:04 AM
jd_sylvia's Avatar
jd_sylvia
Trsshh
I hate to sound like a broken record but I compltely rebuilt my brakes on the front of my 65 F100 2wd a while back. New drums, slave cylinders, shoes, and all new hardware and they still do not work the way I would like so I am now getting ready to convert to power disc brakes in the front.
This upgrade is relatively simple and will cost a little more than what I put into the front drum overhaul (money down the drain).
Unless you want a completely original restoration I would say go disc...The disc brakes I am installing are from a 77 Ford F100. I am using rebuilt calipers, new pads and a new master cylinder with freshly turned rotors.
This conversion has been successfuly completed by several members here on this site and there is a tech article that will guide thru the steps and procedures needed.
Good luck
Old Sep 10, 2006 | 02:33 PM
bob s jr's Avatar
bob s jr
had a old pair out back stamped no 11.080 max diameter
Old Sep 10, 2006 | 03:31 PM
trsshh's Avatar
trsshh
thanks that is what I was looking for.
Sandra
Old Sep 10, 2006 | 03:35 PM
bob s jr's Avatar
bob s jr
your welcome
Realslowww
Dec 9, 2016 10:20 PM
Noahvanmatre
27
May 27, 2016 06:15 PM
gtotiger65
May 14, 2016 01:58 PM
wagon burner
1983 - 2012 Ranger & B-Series
Jun 5, 2012 04:37 PM
awhtx
Large Truck
Mar 25, 2010 01:35 PM
