coil springs ?
Old Sep 9, 2006 | 01:05 PM
jaydgraff's Avatar
jaydgraff
coil springs ?
Yesterday I pull the front coil springs off of my 1966 F-250 2X4, My mistake was I did not labels them, left and right, didn't think I needed to. Today after sandblasting them I noticed one was shorter than the other. Does any one know why? and which one goes where?
Old Sep 9, 2006 | 03:18 PM
Young_unn's Avatar
Young_unn
coudl it be that the driver side one is sagged a little from there always being weight on that side fromthe driver.
im just guessing i have absolutly no idea
Old Sep 9, 2006 | 05:04 PM
User 71024's Avatar
User 71024
they should both be the same length, may be time for a new set.
Old Sep 9, 2006 | 07:48 PM
barry's Avatar
barry
Right and left are identical and Ford always recommends you replace in pairs. If one is shorter, it's on the way out. It's lost it's tension. Time for 2 new ones. Any good front end or spring shop can get them as some auto parts stores. Moog still makes alot of older springs.
Barry
Old Sep 9, 2006 | 10:50 PM
jaydgraff's Avatar
jaydgraff
1) Moog Coil Springs Coil Spring: Front Suspension; Heavy Duty 2) Moog Tuff Coil Coil Spring: Front Suspension; Std. Cab; With 6900 Gvw Or Less; Variable Rate. Found these at advance auto parts, F-250 with 352 converted to a 390. I am thinking the variable rate would be better, or would the heavy duty be the coice?
Old Sep 9, 2006 | 10:52 PM
seventyseven250's Avatar
seventyseven250
I would think the variable rate ones would ride better when unloaded.
Old Sep 10, 2006 | 03:53 PM
bob s jr's Avatar
bob s jr
vary rate work good for driving and 4 wheeling not good for alot of hauling
