C6 leaking through weep hole
Old Sep 9, 2006 | 06:24 PM
Terrible Creek's Avatar
Terrible Creek
Hi all,
I'm pretty much new to these forums and relatively new to Ford pickup. I recently bought a '70 F-100 and everything seems to be mechanically sound for the most part except the transmission leaks through the weep hole in the inspection plate pretty good after driving. It seems to leak worse when it's filled to 'full' on the dipstick and a little less when I keep it just over 'add'. It seems to run fine like that, no driveability issues. The vacuum hose connected to the modulator has good vacuum and is bone dry. The kickdown shaft is disconnected.
A few questions:
1) Would this be indicative of a pump problem or front seal?
2) Does it need to be addressed ASAP or can I continue adding fluid until I have a chance to address it more at my leisure?
3) Based on searching here it looks like if it is a front seal or pump problem and not something more serious I would need to pull the transmission and replace the offending parts with the transmission in a vertical orientation?
4) Should the TC be replaced, as well (assuming it doesn't look like it's the problem)?
Thanks!
Old Sep 9, 2006 | 11:07 PM
stuart1's Avatar
stuart1
If it has never been opened chances are the seals are brittle.
You could try adding some conditioner and attend church on a regular basis or bite the bullet and replace it.
Old Sep 10, 2006 | 09:59 AM
Terrible Creek
I just got back from church and it's still leaking, so I'll probably try to take some kind of action.
1955effie
Sep 13, 2016 07:56 PM
E55 Bulldog
Apr 24, 2016 07:27 PM
lorolr
Oct 19, 2011 11:44 PM
cosmicbrian
Mar 6, 2007 09:55 PM
mike L
May 24, 2006 07:45 AM
