General Diesel Discussion
engine oil
Old Sep 15, 2006 | 08:50 PM
bigtorque's Avatar
bigtorque
sorry clux, i cant loan money for 3 months just so you can pay me back for the oil, which im pretty positive you would be, but, when I hit 10000, i will post my UOA for all to see, better or worse.................. also, you T/C is slipping untill you get past 3 gear on a stock E40D/4R100. the facorty lock up is between 3 and 4th, there for, up untill that point if your motor is spinning with ease due to increased lubrication, it will lower you rpms untill it is locked up. unless you have a lock up over ride. also, a few months ago the show hot rod tv, did a camaro with royal purple motor oil v/ stock, buy changing the oil the dyno showed at the same rpm. 6 more horse power...........so in that case if they ran less rpm they would have achieved the stock horse power level. are you starting to come around.
thanks for all the chatting, but must run wife to dinner, be back tomorrow...
Old Sep 15, 2006 | 09:18 PM
Kwikkordead's Avatar
Kwikkordead
I'm sorry folks, I have to shut this thread down. Bigtorque please read the guidelines.
https://www.ford-trucks.com/guidelines.html
02GrayPowerStroke
Mar 15, 2015 09:17 PM
Chris89lx
Jul 20, 2009 10:25 AM
WilliesSD250
Alaska Chapter
Sep 16, 2006 04:43 PM
chrisbeery
Sep 25, 2005 11:06 AM
Chris R
Jan 19, 2000 08:30 AM
