starter problems
Old Sep 6, 2006 | 02:11 PM
abigaildevore's Avatar
abigaildevore
starter problems
bendex wont disengage. any help? just put in new altenator, now bendex is messed up
Old Sep 6, 2006 | 06:22 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Reman starter is about $135.
Old Sep 6, 2006 | 09:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle
abigaildevore,
Welcome to FTE and the IDI diesel forum.
Look for a place that rebuilds starters and alternators local to you.
You may be able to get the starter fixed for much less if you can find one.
Old Sep 7, 2006 | 04:18 PM
abigaildevore
starter problems
The starter is brand new too, bendex wont disengage, took starter back got a nother new one and it is doing the same thing. can hear it spinning like crazy. tried turning the key back some and that didnt help either.
Old Sep 7, 2006 | 09:10 PM
KJLYPW's Avatar
KJLYPW
Replace the soiliniod on the passanger side fender. Relays tend to fail in the closed position when the contacts arch weld themselves togeather. You can confrim if this is the case if you have continuity with an ohm meter across the big terminals with the key in the off position.
Old Sep 8, 2006 | 08:59 PM
Dave Sponaugle
Sounds like a wire in the wrong place.
There are two solenoids on the starter.
One up on the inner fender, one on the starter.
The upper solenoid has a 10 AWG wire that runs to the bottom solenoid.
The bottom solenoid is actually what cranks the engine.
Check the small wire on the bottom solenoid and make sure it is not shorting out to the battery terminal on that solenoid.
If the battery wire is installed in the wrong position it is easy for it to hit the terminal for the small wire which energises the lower solenoid.
Amandine
Apr 9, 2014 03:37 PM
needhelp49
Jun 13, 2013 10:14 PM
oldtexasdog
May 29, 2011 04:15 PM
Daplumma
17
Oct 23, 2006 09:14 PM
Jcoup
Mar 18, 2005 03:44 PM
