i put a flat-o-matic behind my 239 and that works great but my starter stays a little engaged. I've tried just about everything i can think of even got the newer style bendex but it wont even fit in there. At this point i really don't have 200 bucks for a new starter. anyone got a fix?
thought about it except the flathead starter pulls the drive into the flexplate not push so if i shim it will move the gear closer to flex plate not further
Is the starter shaft parallel to the crank? If it's just binding, shimming one side could allow it to clear. If it's truly too short, then the starter gear/shaft is just built bad from the start, no? Maybe an expert will chime in.
