Antifreeze
Old Sep 6, 2006 | 08:37 AM
ford429cu's Avatar
ford429cu
Antifreeze
I have a 99 Ranger 4x4 4.0 with 115,000 miles and one day I noticed that the temp gauge was reading very high. Once it cooled down I took the radiator cap off and noticed that the radiator was low, it was down just about a gallon. It's been about a month now and about 2000 miles later with no problems other than when I shut off the truck I an can smell antifreeze but don't see any drips on the engine, ground or in the oil. Today I put the heater on high and there was a pretty strong smell of antifreeze inside the cab, do you guys think the heater core is the problem or something else? I haven't seen any antifreeze inside the cab nor did the carpet feel wet or sticky from it in the pass. side area. Any help would be great.
Thanks,
Jeff
Old Sep 6, 2006 | 09:18 AM
Rockledge's Avatar
Rockledge
Have you been checking the heater hoses, as well?
One possibility is that the heater core could have a pinpoint leak which might be allowing enough coolant to get into the plenum (which would explain the coolant smell with the fan on) but yet there's not enough coolant at any given time to make its way on to the cab floor.
Old Sep 6, 2006 | 10:47 AM
pawpaw's Avatar
pawpaw
Check the AC condensate drip tube & see if you find signs of coolant there.
If so, suspect a heater core leak.
You could try bypassing the heater core & see if that solves the problem.
Old Sep 6, 2006 | 12:32 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Go rent a pressure tester for cooling systems and do an overnight test, looking for liquid and pressure drop.
Old Sep 11, 2006 | 02:52 PM
ford429cu's Avatar
ford429cu
Sorry it's been a while, I've been so busy the past week and I really appreciate the help, thanks. I did get a chance to look under the truck at the A/C condensor condensation and it didn't appear to be mixed with antifreeze. The other day I was driving the truck in 50 degree weather at 40-50 MPH for 20 mins with the heat dial in the red zone an the fan off and the truck barely made it up to operating temp. After this I got on the highway doing 65MPH and it warmed up a little more but not to where it should be at. So I put the dial at cool and kept the fan at the lowest setting and the truck warmed right up to operating temp, but as soon as I went to put the heat on the temp dropped off and there was very little heat comming out of the vents. There was no smell of antifreeze inside while driving or outside after I parked it. Any ideas on what could be causeing this?
Thanks,
Jeff
Old Sep 11, 2006 | 03:06 PM
wtroger's Avatar
wtroger
sounds like there is a thermostat issue. Heater core is a small radiator and at it is enough to cool an engine. If thermostat is stuck partial opne this could explain what you are seeing.
Old Sep 11, 2006 | 03:10 PM
pawpaw's Avatar
pawpaw
Sounds like the themostat is stuck open, such that the engine is overcooling.
On your first post about smelling coolant in the cab. Thinking about what Rockledge & Bill said about slow leaks, check the conensate drain tube after a overnight rest. If the coolant leak is small, it could get dilluted wih AC condensate & you'd miss it.
Also thinking about your first reporting the radiator being down on coolant & having an apparant trend for it to want to overheat then, maybe it's time for a new Motorcraft radiator cap.
The coolant system pressure test Bill was suggesting, could uncover a pinhole leak & a radiator cap pressure tester could tattle on it, if it's bad.
Most autoparts stores have these esters on their "Loan-A-Tool" program.
Begining to sound like you may have more than one problem here.
Let us know how it goes.
Old Sep 11, 2006 | 03:51 PM
AmazonRanger's Avatar
AmazonRanger
I would be suspect of a head gasket. Coolant loss with no visable signs of a leak points me in that direction. Do you get any white smoke on initial startup or under hard acceleration? Any signs of the preverbial milkshake under the filler cap?
dws
Old Sep 15, 2006 | 03:23 PM
ford429cu's Avatar
ford429cu
I put in a new thermostat and that solved the running cool condition. I haven't seen any whitish smoke on hard acceleration or on start-ups. I've been checking the radiator daily and it hasn't been down at all in a couple of weeks now so I'm not too sure where it was going before, but I will be keeping an eye on it. Since changing the thermostat there is only a slight smell outside and no smell inside, even with the heat on. Under the oil fill cap there is no milky residue, nor is there any on the dip stick. Thanks for all the help you guys and keep up the good work. This site is the best!
Jeff
Old Sep 15, 2006 | 05:53 PM
pawpaw's Avatar
pawpaw
Jeff, are you actually removing the radiator cap to check it's fluid level, or are you monitoring the overflow coolant tank level?????
When you first found the coolant level in the radiator was about a gallon low, was there any coolant at all in the coolant recovery tank????
Old Sep 16, 2006 | 10:40 AM
ford429cu's Avatar
ford429cu
I've been checking the overflow when cool to see where the fluid level is in relation to the cool line on the side of that tank. I also have been checking under the radiator cap, and that has been full.
Jeff
Old Sep 16, 2006 | 01:24 PM
pawpaw's Avatar
pawpaw
OK good.
Now, when you first posted about the radiator being about a gallon low, was there any coolant in the recovery tank at that time?????
