new novice.
need help. Have /78 F100 Ranger with 302 and 4 speed tran., step-side, short box. Like to convert to 5 speed tran. Also have an /88 F150 with 5 speed. Great tranny and would like to get same tranny for the F100. Is this possible? all input and comments appreciated. Yes, I am a true novice. Thanks guys.
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
You have a couple options - get a adapter to mount a dodge nv4500 to your bellhousing or get a new ford 5spd out of a newer pickup with 300, 302, 351w. The nv4500 is a strong 5spd trans and will allow you to use your original clutch linkages. The Ford 5spd is cheaper and plenty strong for a 300, but you will need to fabricate a hydrolic clutch system.
Check the tech articles in the Articles/Specs link at top of page.
