360/390 engine swap
Old May 14, 2001 | 02:35 PM
77ford's Avatar
77ford
360/390 engine swap
I have found a 1966 f250 with a 390/automatic trans, 2-wheel drive, for sale at a good price. I would like buy the truck and use the 390 to repalace the 360 in my 1975 f100/4-speed 4x4. If i understand the other post i have read this shouldnt be a problem. Just want to make sure before I buy it. Are the motor mounts the same ? What problems might i encounter because of the different transmissions ? and will make any difference because its coming out of a 2-wheel drive ?
Thanks for tolerating this novice question.
Old May 14, 2001 | 03:23 PM
mattn's Avatar
mattn
360/390 engine swap
This should be a direct swap. Are you keeping the 4-spd? If so you will have to keep the flywheel/clutch out of your truck. However, this is no big deal.
I would recommend keeping the acc. brackets off your current motor. And possibly the emissions stuff (if you still have it all attached). Becouse your truck is a '75, it probably isn't required to take smog tests. This would simplify things considerably. If you do, and you want to keep it smog legal, you maybe would need to swap the intake and possible the cylinder heads (for the EGR crossover). The '66 motor might not have these passages on it. I am not that familar with the smog components on the FE
The 360 and the 390 use the same block (same bore). The crank is what seperates these two motors.
MattN
70 F100 2wd
302 3-spd man
Sweetest little blue truck I own!!!
Old May 14, 2001 | 05:38 PM
jowilker's Avatar
jowilker
360/390 engine swap
Doug, Just put a 390 crank and piston set in your 360 and you will have a 390, with out other parts to deal with.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old May 14, 2001 | 05:52 PM
FE427TP's Avatar
FE427TP
360/390 engine swap
You will need to swap the oil pan, the oil pump pickup add a pilot bearing to the back of the crank, and swap the flywheel onto where the flexplate was. The reason for swapping the oil pan and pickup tube that bolts onto the oil pump is because the 4x4 oil pans are deep in the back and the 2 wheel drive ones are deep in the front of the engine, the reason the 4x4 are deep in back is to clear the suspension same with the 2 wheel drive and why it's deep in front, you'll need the pilot bushing for going into the crankshaft for the front shaft of the transmission. When swapping the oil pump pickup tube you might want to step up to a high volume oil pump, or at least just get a new oil pump and oil pump driveshaft because this will be the easiest time to do it while the engine is outside of the vehicle. Total cost about $45.
Old May 15, 2001 | 04:43 AM
karljay's Avatar
karljay
360/390 engine swap
I'd make sure the 390 is really a 390. I was told once that it was a 390 only to find it was a 360 and you can't really tell from the outside. I think the crank of the 390 has a square notch and the 360 has a round notch at the flywheel end. I'd also check the overall condition and compression because it might be better to convert your 360 to a 390.
Old May 15, 2001 | 06:26 AM
jowilker's Avatar
jowilker
360/390 engine swap
Cal & Karl in the 65, he will need to make sure it isn't a 352. If it is already in a truck, I don't think he would have to make those changes that you suggested, right? ;-)
John
jowilker
66F100s Rule
Old May 15, 2001 | 09:49 AM
pto dave's Avatar
pto dave
360/390 engine swap
Old May 31, 2012 | 06:35 PM
FORDCOWBOY13's Avatar
FORDCOWBOY13
LITTLE ENGINE SWAP HELP IF YOU WILL FELLAS
I have a '75 f250 highboy A/T full time 4wd running a 360 block and a holley 1850 600cfm carb. Now me and my buddy have rebuilt and tried to dial the carb in several times but it just wont dial in right. We have talked about the possibility of dropping a 6.9l with manual tranny. I am aware of having to fab new linkage and motor mounts. I am curious first if it will be worth the possible frustration and then if I will need to change my T-case? Turbo or not and what if it even matters should I be year specific? Would it make any benefit to the project to consider a 1st or 2nd year 7.3l turbo or not? I am certain there will be many finite parts to this process I am most likely overlooking so any additional knowledge to help me would be most appreciated. Thanks for the site and helping this new member.
Old May 31, 2012 | 07:07 PM
HIO Silver's Avatar
HIO Silver
In addition to the previous responses (pilot bushing, rear sump pan & pickup), flywheel/clutch, etc.) the oil filter housing also needs to be swapped. 2wd housings point straight out and 4wds are 90-degrees.
John
jowilker
It's believe it's the crank and rods.
deronyv8
May 10, 2016 09:09 PM
teched
Apr 1, 2016 12:06 PM
kadrocker
Jan 23, 2016 09:23 PM
Fordmaster1974
Nov 7, 2007 09:40 AM
1975 f150 360
Oct 17, 2003 12:35 PM
