the spout
Old Sep 3, 2006 | 03:08 PM
herby666's Avatar
herby666
the spout
what exactly does the Spout do - what is it for ???
Old Sep 3, 2006 | 04:26 PM
mrshorty's Avatar
mrshorty
SPOUT stands for SPark OUTput. The EEC-IV computer gets information (cylinder ID, PIP TACH signal, etc.) from the ICM. The EEC_IV computer then calculates the desired spark advance from this information and other information (MAP signal, TPS signal, etc). This SPark OUTput advance signal is then sent to the ICM which controls the firing of the spark plugs. If the ICM doesn't get any signal from the SPOUT circuit, then the ICM fires the spark plugs at a fixed "base" timing -- usually 10 BTDC (which is why you unplug the SPOUT connector when setting base timing, to disable the timing advance).
badaz4570
Sep 11, 2014 11:32 AM
Iantiler
19
Jul 15, 2008 09:23 PM
61F750
Feb 18, 2006 12:16 PM
RyanJake
Jun 29, 2004 06:18 AM
Boldt
19
Jan 8, 2003 11:51 AM
