Sponsored by: Auxito
Would anyone suggest.........
Old Sep 2, 2006 | 10:26 PM
looneylariat's Avatar
looneylariat
Question Would anyone suggest.........
I bought a B&M shift kit from Summit for my '99 F-150 4.6. I am second guessing myself as to install it or not. My truck has 124K miles on it. Do you think I would be ruining my transmission by installing this kit with so many miles on it? I can't decide what to do and don't know if the firmer shifting would progress the deteriation of my tranny. Any help is greatly appreciated!
Old Sep 3, 2006 | 01:13 PM
BowTieHatr's Avatar
BowTieHatr
my thoughts are unless you notice any problems (delayed shifting, slipping, etc) i would go for it. it bumps up the pressure and thats is why the shifts are firm. more pressure is less slippage in the clutches.
Old Sep 3, 2006 | 01:26 PM
PatchMcGav's Avatar
PatchMcGav
As long as you keep up with regular maintenance it shouldnt hurt, like said before it just ups pressure and prevents slippage..
Old Sep 3, 2006 | 02:39 PM
looneylariat
Unfortunatley, the trucks transmission has never been serviced. No tranny fluid or filter changes the whole 124K miles. Of course I will change the fluid and filter when doing the kit or even if I don't do the kit. Your explanations of how the kit works makes sense. So basically the kit does no damage to your tranny, if I'm reading it right. I wonder why trucks intended for towing and heavy duty use do not already come with an improved shifting tranny from the factory?
Old Sep 3, 2006 | 07:17 PM
BowTieHatr's Avatar
BowTieHatr
because the factory is wanting longevity, and comfort. they have to find a happy medium. just a heaqds up, if fluid never been changed, you might notice slippage with new fluid. i would do a fluid change then drive for 1500-2000 miles just to make sure everything is ok.
Old Sep 4, 2006 | 11:09 AM
ggarrahan's Avatar
ggarrahan
looney- You have a transmission that's currently working ok, right? And, all the components have worn in together for 124K miles, right? So now you want to modify the valve body to increase line pressures, on clutch packs with 124K miles on them. I wouldn't! If it ain't broke, don't fix it. Unless, of course, you really want to rebuild the transmission.
Old Sep 4, 2006 | 05:41 PM
looneylariat
I am thinking on the same lines as you GG. I think I'll go with a fluid change and skip the kit. Thanks for all the advise!
I was just trying to get a little more oomph out of my old 4.6
Roger T. Pipe
16
Mar 25, 2020 05:45 AM
72Highboy4x4
1997 - 2003 F150
Oct 30, 2012 08:44 PM
MisterCMK
Oct 1, 2008 04:01 PM
Marc150
Mar 3, 2006 04:50 AM
DictatorDanny
Mar 17, 2005 07:58 PM
