Points or electric dist or mag pickup? I don't know much about points, but I would think switched power and leads to the coil would be it. Duraspark 2 has three leads from the dist, and mag pickup has a signal and return lead.
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
That switch applies to a certain run of Ford vehicles (Trucks) .
The cut-off is in the either the 77 or 78 Model year.
For instance :
I have a brand new switch here that is in an open bag with one part number on it.....in a Ford box with another part number labeled on it.......and the part itself with the PIN on it ..............................so , the only way to tell for sure what it is... is to look at the FORD part identification number stamped on the part itself.
