3-Speed to 4-speed
Old Jan 4, 2002 | 01:28 PM
rdnck4x4's Avatar
rdnck4x4
3-Speed to 4-speed
What all would be required to go from a 3-speed to a 4-speed? I already have a new throwout bearing and 10-inch clutch disc for a 240 strait six and a 3-speed. I am planning to rebuild the 240 and it would be great if i could use those parts for the 3-speed. Basically i am wondering about parts interchangability,any advice you can give me,and recomendations on what kind of 4-speed to get.A 4-speed with a granny-low first would be nice.....
Old Jan 4, 2002 | 01:41 PM
Rosati's Avatar
Rosati
3-Speed to 4-speed
I'm not sure about the clutch disk and related parts, but you will have to raise the tranny hump in the cab for clearance. your 4-speed will usually be a toploader where the 3-speed uses side linkages and the clearances are different.
You did not mention what you are driving but I assume it a 65 or 66.
Krosati
[link:www.ford-trucks.com/user_gallery/displayalbum.php?&albumid=28|My User Gallery]
Visit my homepage at ClubFTE
[link:www.clubfte.com/users/krosati/index.html|My Homepage]
My friends say I'm too old to play with toys.
I need new friends
Old Jan 4, 2002 | 03:55 PM
rdnck4x4's Avatar
rdnck4x4
3-Speed to 4-speed
How strong is the 3-speed? The 240 rebuild is going to be mostly stock. Just a slight performance cam. It is a 66.
Old Jan 4, 2002 | 05:12 PM
jowilker's Avatar
jowilker
3-Speed to 4-speed
It's strong enough to handle anything that the little six can throw at it, you are not dealing with gm parts. :-)
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jan 4, 2002 | 06:54 PM
MatthewB's Avatar
MatthewB
Post 3-Speed to 4-speed
Has anyone put a toploader 4 speed(car,no granny gear) to replace the standard 3 speed in a '65 352 long bed? Curious about trans mount,drive shaft, can I use existing bellhouse? thanks.
Old Jan 5, 2002 | 01:07 AM
pntrbil's Avatar
pntrbil
3-Speed to 4-speed
I've been wondering about putting a 4 spd toploader in my 65 F250 myself. I've been under there looking at where the tranny bolts to the bellhousing and it LOOKS like it'll work. As I understand it, after 64 toploaders had a rectangular pattern that at least resembles my bellhousing and I know toploaders did come behind FE mills in post 67 Mustangs. The bellhousings exist. I hear pre-64 toploaders had a narrow pattern on the top 2 bolts so I'd stay away from those.
Assuming the truck and Mustang bellhousings are the same then there are no complications with the clutch. The clutch disc may have to be matched up to the toploader input shaft but again, they once came in Mustangs. Have to be out there.
For trans mounts? That's why we have steel and welders! LOL! You can get just about anything made up for a driveshaft. And that leaves the shifter. I suspect it comes up way behind where my truck shifter is but there's a lot of floor there.
What I'm really looking for is an overdrive toploader. They have the usual 4 spd's but the shift fork for the 3-4 slot gets reversed or something, so 3rd becomes the 1 to 1 drive that's usually the top gear. 4th is a .84 or .87? Can't remember, but I did do the calculation and figured it'd be a 2.97 final drive. That'd get me loafing down the freeways!
Old Jan 5, 2002 | 09:29 AM
truckfarmer's Avatar
truckfarmer
I had a 66 with a 300 and put a 3speed+ overdrive from a 78 F150 in it. It worked out great. Got over 20MPG with that combo. The spread between 2nd and 3rd is quite a jump though. My local junkyard has one in a 85 F150 they just got.
Old Jan 7, 2002 | 11:58 AM
jcs1966's Avatar
jcs1966
3-Speed to 4-speed
My "race truck" has a Cougar car 4 - speed installed in it. The prior owner had to shorten the driveshaft because the transmsiion tail was longer. He never got the speedometer recaliburated. This driveline is for sale in classiffied.
Old Jan 7, 2002 | 12:01 PM
jcs1966's Avatar
jcs1966
3-Speed to 4-speed
sipe33
Apr 5, 2017 05:23 PM
hillcountryflt
May 9, 2016 08:00 AM
Grape Nehi
Aug 4, 2015 01:54 PM
TheRooster12
Dec 15, 2010 10:37 AM
androgen
May 30, 2002 08:38 AM
