4.9L Code Translation
Old Aug 29, 2006 | 01:14 PM
PSW's Avatar
PSW
I used the Check Engine light (MIL) to pull the following codes from my
1992 F-150, 4.9L-6, automatic, 2WD.
KEY-ON, ENGINE-OFF
332: EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
628: Excessive converter clutch slippage - Transmissions (Also saw another interpretation of this code as "Lockup solenoid circuit circuit failure.")
KEY-ON, ENGINE-ON
172: Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
332:
538:
(R) System did not receive "goose" test - TESTS
Can I make these repairs myself? I've done tuneups, brakes, etc. and have tools. What parts do I need? Or do I need to find a mechanic?
Thanx for yr help, PW
twoballsleft
Jan 8, 2022 07:32 PM
megawatt00
52
Sep 25, 2012 06:01 PM
Gabe742
Apr 17, 2012 01:48 PM
BaitGuru
May 12, 2010 11:14 AM
Smokey1961
Jan 17, 2009 04:05 PM
