fuel heater change
Old Aug 28, 2006 | 10:21 PM
gerald tompkins's Avatar
gerald tompkins
fuel heater change
hi i have found the fuel heater to be shorting out and blowing my fuse.so i disconected for the summer. would like some instruction on how to change both the inturnal and exturnal parts.it looks like all i need is a phillips for the exturnal ,but don't have a clue what the inturnal part looks like.i have a 1999 f 250 thank you
Old Aug 29, 2006 | 09:50 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
On the outside you remove the two screws and remove the thermostat from the filter housing.
Inside, once the filter bowl is drained and filter removed, disconnect the spade connector and remove the two screws holding the heater element down.
Old Aug 29, 2006 | 10:49 AM
BowDown's Avatar
BowDown
internal/external
Old Aug 29, 2006 | 07:04 PM
gerald tompkins
cookie 88 thank you
Old Aug 30, 2006 | 08:27 AM
renchr56's Avatar
renchr56
Hey Cookie don't you have to remove that center piece? As I had to on my f-550's
Old Aug 30, 2006 | 09:56 AM
cookie88's Avatar
cookie88
FTE Emeritus
If I remember correctly the nut for the center stud is under the element on the Superduty....but the filter bowl is the same 250-550, so maybe my memory is fuzzy.
Old Aug 30, 2006 | 10:03 AM
renchr56's Avatar
renchr56
I had to make a longer socket to go over the extension pipe. I broke one because I found that it was left hand threads
59f100292
Aug 11, 2009 09:27 AM
buck_
Aug 28, 2006 06:56 PM
Big Rig
Jun 9, 2005 08:36 PM
Platinum01
Feb 23, 2005 09:23 PM
dalonso
3.8 & 4.2L V6
Jan 23, 2004 01:29 PM
