hi 9d4,
put your AWD Aero up on ramps....block wheels all 4....get a 4' section of garden hose to use as listening device
listen to individual areas on engine top, bottom, front timing chain cover water pump and bell housing to pinpoint knock noise
When removing the 4.0 pan you may have to rotate the crank to get counterweights out of the way. when the front counterweights are up, the pan is easy to remove.
