rod knock testing
Old Jun 22, 2003 | 08:04 AM
Pick-up Line's Avatar
Pick-up Line
rod knock testing
I read in this forum about testing for a rod nock by removing the plugs one by one till the knocking stops. Should I do this while the engine is running or do I stop the motor in between each plug I pull? And I am pulling the plug wire not the entire spark plug, correct?
I have a '93 F-150 5.8L 150,000mi that has started knocking. On my last oil change, I took the truck to a dealership to get a little insight as to what they thought the knocking was coming from. They said it sounded like it may be low end and at the mileage I have replacing the motor was my only option.
I was told before that the knocking was lifter related, and didn't really pose a problem, but after my last oil change (10W 30) the knocking was more evident, till I added a pint of STP oil treatment. Now knocking is noticed on RPMs below 2000.
Thanks for any advice, my intent is to take it to a reliable mechanic, but I don't want to get reamed in the end.
Gary
Old Jun 22, 2003 | 08:28 AM
Bob Ayers's Avatar
Bob Ayers
rod knock testing
Yes, pull the spark plug wires one at a time while it is running.
DIYMechanick
Oct 21, 2016 05:42 PM
rock2610d
Modular V10 (6.8l)
30
Jul 8, 2016 07:54 PM
PEG
1997 - 2003 F150
Nov 18, 2015 12:55 PM
timbo670
Modular V8 (4.6L, 5.4L)
Oct 26, 2012 01:28 PM
Trail Master
Apr 10, 2004 08:05 PM
