Headers suck......
Old Aug 27, 2006 | 08:58 PM
terrypen's Avatar
terrypen
Cool Headers suck......
I tried for about 2 hours this morning to get the passenger side exhaust system on the DynoMax Black Jack headers. Finally gave up and called it a day. They are really close to that crossmember at the rear of the engine. I think that I'll have to loosen all the bolts on that header, put the exhaust on then tighten them back up.
I'm really wanting all this to be over and driving that 65 again.
Old Aug 27, 2006 | 09:32 PM
jd_sylvia's Avatar
jd_sylvia
I have the HeadMan headers but had a simular problem. I ground a notch in the flange to allow a bit more movement and it made life easier.
Good luck
Old Aug 27, 2006 | 10:01 PM
terrypen's Avatar
terrypen
Good luck
notch the flange??? I can't visualize that, it appears that I'd have to notch the crossmember to fix this. Hopefully, loosening those header bolts and then mounting and retorqueing header bolts will work.
Old Aug 27, 2006 | 10:10 PM
jd_sylvia's Avatar
jd_sylvia
The three bolt flange on the Headman rotates so I just took some material off to get it to move a bit easier since it was tight up against the cross member.
I did this while I was installing them so they were not mounted yet.
Again good luck..
Old Aug 27, 2006 | 10:13 PM
airharley's Avatar
airharley
If you have any kind of TQing of the motor you may end up with a few bolts that snap with no space around the flange. So be careful.
Old Aug 28, 2006 | 08:21 AM
terrypen's Avatar
terrypen
I think that once I get them on, the bolts on the flange(is that the correct name? the triangle shaped mounting hardware) will slide down the forward side of the crossmember. It's just too close to get the bolts started, I can get one bolt started but then the second one is real close. The third is no where close to where I can get a bolt in it.
Those stock manifolds are starting to look really good sitting in the bed.
Old Aug 28, 2006 | 08:30 AM
terrypen's Avatar
terrypen
Again good luck..
Well, hindsight is ALWAYS 20/20.... I put the thicker flange on thinking, "thicker is better." My slo-par buddy is just laughing at me as he's had some of these issues on his old Charger.
MrRogers
May 22, 2007 12:29 PM
skips69
Exhaust Systems
Feb 21, 2005 10:28 PM
BB
Feb 16, 2002 07:22 PM
73Custom
16
Apr 17, 2001 01:18 PM
