Timing timing timing
I just got done rebuilding my 89 302 new bearing gaskets timing chain to be exact put the motor in wont start i have spark compression when i put the timing chain on i had the two dots lined up. when you put the timing chain in should i have # 1 piston set at TDC ? If someone can please tell me step by step how to set the timing and also the rotor is pointing at #1 piston.
Thanks
Tom
Sometimes you need to try moving the dizzy around a bit to get it close enough to fire up. With number 1 at TDC, point the rotor at the number one wire terminal, or slightly ahead. It could be off one tooth and not fire. Once you get it to fire up and stay running, you can time it with a timing light. What about the fuel system?
It's probably something simple. My brother had trouble starting up a 351 recently but it turned out that wires were just put on in the wrong firing order.
probably not relevant but...
As P51D mentioned, check the firing order and if the dist. has been stabbed properly.
now i was told it is an 89 302 but when i bought a cap and rotor for it didnt match it matched to a 82 302 so i think im in a hole new ball game now
on the heads i seen TG13 TG14< what would this be i found this number in between #2 and #3 is this the identification number if not where can i find it at
also on the rockers there are letters on them ABCD does those mean anything
When i first got the truck he had the vacum line from the distributor to the carb is that the correct spot for it
when the truck idels it dont back fire put it in gear try to drive it back fires and dies out
the rocker arms are the non adjustable or do they have to be adjusted to a certain specification for a 82 302
thanks
Tom
Roller cam motors and flat tappet motors do use different length pushrods, and you must have the right ones for the application. Roller cam pushrod length is 6.27" Flat tappet pushrod length is 6.905". For 60's 289/302 with adjustable rockers for solid lifters it's 6.804".
If it's a 82 motor it should have flat tappets. The lifter and cam lobe break in to each other. If cam and lifters are ever re-used they must go always to the exact same cam lobe they broke in on. Otherwise you will have major problems. Some people also feel that the rocker and pushrod must remain in the same positions, and that rockers must also be used on the same valve stems. A new cam and lifter set should be broken in using a special procedure, with plenty of break in lube on the cam lobes before first start up.
this is how it all happen took the truck out friday night just crusing around town ran great and quiet pressure washed the motor saturday drove around no knocking running great parked it listened to the motor no knocking sunday morning woke up started the truck knocking like hell drain the oil water came out first then oil i dont know how water got in the motor checked it all out head gaskets were fine everything was fine im thinking someone was pissed because my truck was better and faster then there chevy and i only know 2 people with chevy trucks that i raced and killed them stock 302 vs stock 350s and i think you all know how pissed of chevy guys get
well thanks again for the help
i got to go destroy some chevys
