changing bulb on transmission indicator
Old Aug 25, 2006 | 12:35 AM
fatherdoug's Avatar
fatherdoug
I need to change the bulb on the shift selector dial for a 1978 F-150 with the C-6 transmission. It has the tilt wheel. What is involved in getting at the bulb to replace it?
I posted this in the transmission section, but got no response.
Old Aug 25, 2006 | 01:15 AM
Mil1ion's Avatar
Mil1ion
Get yourself a long needle nose pliers.
Remove the plastic cowl attached to the dash that covers the bottom of the column....
You will see a single blue/red striped wire
That's for the bulb.
Now Reach up inside the steering column and pull the light bulb socket out with the pliers.
*NOTE: Just Pulling on the wire will break the wire off the little contact inside the socket.
Installation is the opposite
BigRed1967
Oct 1, 2023 11:00 AM
RockAuto
Vendor Specials, Discounts, Product Announcements & Group Buys
May 25, 2017 02:41 PM
06greenstroker
Jan 9, 2017 02:11 PM
cyncwby
Jan 3, 2017 01:46 PM
joinerd69
Mar 7, 2003 04:08 PM
