Modular V10 (6.8l)
4r100 filter change
Old Aug 24, 2006 | 11:02 AM
Big Rig's Avatar
Big Rig
4r100 filter change
Guys,
I have been in a Maintenance mode lately and want to drop the tranny pan and replace the 4r100 filter.
Is it as simple as draining the pan, taking the cover off and pulling out the filter and installing a new filter and buttoning everything back up?
If so, how much fluid will come out with only the pan removed?
Big Rig..
02 Ex V-10
Old Aug 24, 2006 | 11:59 AM
bobbo7915's Avatar
bobbo7915
yeah you pretty much sumed it up, not sure exactly how much but i think 5-6 quarts, correct me if im wrong. how bout a shift kit while you have the pan off
Old Aug 24, 2006 | 12:30 PM
superduty lee's Avatar
superduty lee
Keep your drain pan handy after you drain the pan. When you pull the filter out another 1/2 quart will drain out, I found this out the hard way.
Old Aug 24, 2006 | 12:34 PM
Casey's Avatar
Casey
In my opinion changing all of the fluid is more important than changing the filter, but it does not hurt to change the filter, too. Ford has a spec on how often to change the fluid, but no spec on ever changing the filter.
Here's how I change my fluid, and it has an optional step to change the filter, too.
https://www.ford-trucks.com/article/...nsmission.html
Old Aug 24, 2006 | 08:20 PM
Big Rig's Avatar
Big Rig
Well..Got it done today..Piece of cake..Took 8 qts to fill back to full..
Big Rig
Old Aug 25, 2006 | 10:37 AM
ken04's Avatar
ken04
Big Rig
you can get another 2 or 3 quarts of fluid out of the torque converter. It has a drain plug on it, spin it until you see the plug. This should get you close to 10 quarts of fluid to drain. Make sure you feel up inside the filter hole to make sure the old filter gasket comes out. And there are 2 different lengths of filter snouts even though the actual filter is exactly the same. Mine takes the short snout, but my pan won't fit back with the long snouted filter. But if your tranny takes the long snout, and you accidently install the short snouted filter you may not get fluid pick-up.
Old Aug 25, 2006 | 01:27 PM
Casey's Avatar
Casey
The torque converter holds about 8 quarts, not 2 or 3.
The original poster has a 2002, and chances are there is no drain plug on the torque converter. Ford stopped installing drain plugs just after the start of 2002 production. Only the first few 2002s have a drain plug on the converter.
Old Aug 25, 2006 | 01:46 PM
Big Rig's Avatar
Big Rig
Guys,
Thanks for all of the info.
I just drove the EX around today after thinking it was full. I had to add another 1 1/2 qts for a total refill of 9 1/2 qts!! Is this Normal
I just replaced the filter and Mercon..No TC change as there was no drain plug.
The reason I did not do the flush is I just had it done at the dealership 7k ago and I just wanted to change the filter and look at the metal magent for any problems. No problems and very little metal flakes on the magnet.
The dipstick reads just over the hash marks know when it is idling hot.
I'm not sure if this made a difference or not, but the EX had not been driven for about 5 days before doing the tranny change. It sat in my driveway. I did not warm the fluid up. I just started removing the bolts etc. I did look at the level of the fluid when the EX was cold and not running. It was in between the "IF and IN" words on the dipstick, which is way above the hash marks, but I think the level goes down when the engine is on.
plz correct me if I am wrong as I can easily drain some out if you guys think it is over full.
Old Aug 27, 2006 | 10:18 AM
Ricohman's Avatar
Ricohman
Big Rig
I've always used the return line method and replaced the entire dumped (and measured ) amount by volume. And I think it was about 19 quarts or so for the 4R100 behind my V10. Anyone else use this method?
When you only change 10 quarts aren't you leaving behind the other half?
Old Aug 28, 2006 | 01:08 PM
ken04's Avatar
ken04
yes, but I was told once that the factory suggestions for changing the fluid take into account the 6-10 quarts that are changed. Every third change I go to a pump it out place and have them exchange all the fluids. Normally I drop the pan and drain the tq converter myself.
Old Aug 30, 2006 | 03:14 PM
burgf250's Avatar
burgf250
Saskdiesel,
Could you describe the return line method and how to do this. I need to change my Excursion trans fluid and would like to remove as much fluid as possible, but don't want to miss a step and damage the transmission.
Thanks,
Rick
Old Aug 30, 2006 | 08:51 PM
Casey's Avatar
Casey
Old Aug 31, 2006 | 11:44 PM
ptolalibertad's Avatar
ptolalibertad
i heard that doing a complete fluid exchange is bad and causes problems sometimes. anyone heard of this? i mean changing the brake fluid and transmission fluid was'nt brought up until recently??....like within the last 15 years?
Old Sep 1, 2006 | 12:59 PM
Casey's Avatar
Casey
Yes, I've heard people say that. It isn't true. It's an old wive's tale.
Carolina Rig
Jun 5, 2017 01:16 PM
SoCalAngler
May 26, 2017 02:23 PM
bcaughhorn
Nov 17, 2016 04:37 AM
Whitey Ford
15
Feb 10, 2015 06:28 AM
SpringerPop
May 5, 2009 04:49 PM
